ᐅ Is a Separate Meter and Electricity Tariff for an Air-to-Water Heat Pump Beneficial?
Created on: 2 Jun 2021 08:47
_
_Ugeen_
We have an air-to-water heat pump in our newly built house and are considering whether it makes sense to install a separate meter for it and to get a separate tariff. Do you have any experience with this? Is it worthwhile?
Z
Zaba12
7 Jun 2021 10:35
nordanney schrieb:
This is the lowest/basic standard you can choose. 15cm (6 inches) is really borderline.
This is a tight installation – 5cm (2 inches)! But it also means triple the number of pipes.
However, it only works if each loop is no longer than 100m (330 feet). How many loops are there? What is their length?
nordanney
7 Jun 2021 10:36
It is definitely future-oriented, optimized for energy consumption, and beneficial for the future value of the house. And if I’m already spending half a million on a house, I want to do it properly. Not just “good enough.”
The material cost is almost negligible – 100 meters (330 feet) of MSV pipe costs less than 100€ (euros). Stapling just takes more time.
nordanney
7 Jun 2021 10:39
Zaba12 schrieb:
But it only works if each loop is no longer than 100m (330 feet). How many loops are there? How long?
There are three loops in just under 25 sqm (270 sq ft). Each pipe length barely exceeds 100m (330 feet). Almost a perfect fit. It’s not a DIY design but calculated by the engineering firm to match the room heating load.
Deliverer
7 Jun 2021 10:42
There is a sweet spot somewhere. (From experience, it should be around 8cm (3 inches). Although that also depends on the pipe thickness...).
And, of course, the load is lower when the house is better insulated.
The pump doesn’t necessarily have to work harder if the spacing is smaller. Two loops on the same area mean less flow per minute. More important for the pump are proper supply lines between the manifold boxes and the heat pump.
driver55
7 Jun 2021 10:47
This shown "extreme" has, with a real 5 cm (2 inches) thickness, a total heating circuit length of approximately 500 m (550 yards) for 25 m² (270 ft²). Far from the 3 x 100 m (3 x 110 yards) often assumed.
nordanney
7 Jun 2021 10:55
driver55 schrieb:
This shown "extreme" has a total heating circuit length of about 500 m (1,640 ft) for 25 sqm (270 sq ft) with actual 5 cm (2 inches)! Far from 3 x 100 m (3 x 330 ft).
No, it doesn’t – as mentioned, each is a bit over 100 m (330 ft). And it really is 5 cm (2 inches). I installed them myself 😉
In the end, it’s not a big deal if some circuits exceed 100 m (330 ft). It’s a combination of different factors (pump, temperatures, pipe diameter, etc.).
