ᐅ Roller Shutter Wiring – Smart Home
Created on: 12 Jul 2019 13:50
deadlef
deadlef
12 Jul 2019 13:50
I am currently building a turnkey house and have decided to use radio-controlled roller shutter motors. Accordingly, 230 V wiring is being installed to each window. My question is whether it is more practical to have the electrician run a separate cable from the distribution board to each window, or to always branch off somewhere in between. The last time I was on site, I noticed that the electrician seemed to be taking the power supply for the roller shutters from the nearest power outlet. Considering an additional cost of 100 euros for the 230 V installation, that seems quite steep if they only lay about 3 meters (10 feet) of cable. Wouldn’t it be more sensible to install it separately, especially for smart home integration?
Strahleman
12 Jul 2019 14:29
With wireless systems, it doesn’t really matter. The roller shutters are wired in parallel (unless the electrician is really inexperienced), meaning you can control each branched line or supply cable individually. Wiring directly from the distribution board is also possible. However, if everything is on the same 16A circuit breaker (which I assume based on your description), it doesn’t actually make a difference whether you branch off from the outlet or run the cables from the distribution board (the latter even saves a few meters of cable).
Lumpi_LE
12 Jul 2019 14:44
If you are sure that you want to use radio-controlled motors now and forever, then it doesn’t really matter. However, it is better to centralize everything in one place; this way, it is theoretically possible to switch to a different solution later on.
hampshire
12 Jul 2019 17:39
deadlef schrieb:
A surcharge of 100 euros just for the 230V wiring seems quite steep if they only install 3m (10 feet) of cable. Wouldn't it make more sense just for smart home applications, etc.?
With or without chasing the masonry?
danixf
12 Jul 2019 18:39
It’s not ideal, but it will work with the radio motors. However, if one breaks, replacing it will be quite a hassle. It would be better if the “Smart Home” system controlled the switches wirelessly, as swapping those is much easier than replacing a roller shutter motor.
What did you pay the extra 100€ (about $110) for? What else did they want to install there? 12V?
Mycraft12 Jul 2019 19:19
A defective motor is a defective motor, regardless of how it is controlled.
