ᐅ Replace sink with a wall-mounted installation system
Created on: 22 Nov 2020 19:05
SchinkenSpicke
I hope you can help me: In my apartment, the previous tenants removed the washbasin that was mounted on a drywall support frame. At the wash area, I currently have a drywall partition with two holes spaced 28 cm (11 inches) apart, in which I see something that looks like nuts marked M10. Behind these nuts, there appear to be M10 threads/anchors or something similar. I was able to firmly screw an M10 threaded rod into the right hole for the new washbasin, but on the left side it is loose, even though I can’t screw it in any further. It also doesn’t go in as deep as on the right side. What could this indicate? And is it possible to fix this without having to remove the drywall and tiles?
I am a complete beginner when it comes to this kind of thing and I’m quite concerned after discovering this... I will have a plumber come, but I would like to be informed in advance about the options and possible costs. I hope you can give me some advice!
Tassimat
27 Nov 2020 15:07
Addendum: Walraven BIS RapidRail WM2 sliding nut M10
SchinkenSpicke
27 Nov 2020 16:37
Thank you very much for your advice!
Joedreck
27 Nov 2020 17:42
Why is it a landlord problem? The landlord provided an apartment including a washbasin. The appearance doesn’t matter, it worked.
The tenant wants a different one. The tenant must hand over the apartment at the end of the lease in the condition it was accepted. So it’s the tenant’s responsibility. From start to finish.
I would call a plumber. If tiles are damaged, there will be problems.
SchinkenSpicke
27 Nov 2020 23:04
The plumber is coming next week; I will get back to you afterwards and report on the outcome. Unfortunately, I can only find the Walraven BIS RapidRail WM2 sliding nut M10 through wholesale channels, not available for private buyers.
Tassimat
27 Nov 2020 23:14
Ebay has them, but with high shipping costs. Alternatively, any other standard sliding nut for 30 cents might work. Or you could call around to the usual plumbing supply stores.
Anyway, I’m looking forward to the report on how the installer manages to solve it 🙂
SchinkenSpicke
27 Nov 2020 23:39
Keep your fingers crossed that I will have a solution to share...
