ᐅ Repair plaster on facade (base / plinth)
Created on: 12 Apr 2017 15:21
DerRoman
DerRoman
12 Apr 2017 15:21
My wife and I bought a house last year – built in 1978 (so it’s older than we are ).
Now, of course, it’s time for some renovations and repairs.
Yesterday, I noticed that on the rear side of the house at the "base" – roughly at the level of the basement windows – the plaster is damaged. It is loose, and a piece about 5cm by 3cm (2 inches by 1 inch) can be removed. The areas around this removable piece are slightly cracked, and most likely the adhesion will not hold in the medium term.
My question is: How can I fix this myself if possible? I’m not a professional, but I’m reasonably handy. I just want to intervene as quickly as possible to protect the masonry from potential harmful effects (moisture).
I would be very grateful for any advice or tips.
12 Apr 2017 20:01
Hmm, I recently renovated the exterior plaster of our old house before repainting.
I knocked off all loose material and removed any areas that sounded hollow over a large surface.
Then, following the instructions on the repair plaster, I applied the appropriate primer, moistened the surface, and carried out the repairs.
Fine cracks can probably be left as they are.
However, I cannot guarantee this—I am also a non-professional.
Plaster usually detaches when the substrate is damp. It would be important to check the cause. Is the moisture coming from the inside or outside?!
Best regards, Yvonne
Nordlys
12 Apr 2017 23:32
It is rising damp that is damaging the plaster. As ypg says, repair the plaster, but also remove the soil at the base and apply a bitumen waterproof coating. This will prevent moisture from reaching the masonry. Then, no soil directly against the foundation; instead, use gravel, coarse gravel that allows water to drain well. Karsten
DerRoman
15 Apr 2017 15:56
Hello and thank you very much for your advice.
I have now repaired the damage with repair plaster. There is no soil at that spot; rather, it is a recess paved with concrete slabs in front of the window.
The damage looked as follows:
Exterior wall corner with brown plaster and crack next to metal grate.
Close-up of damaged wall with cracks and flaking plaster next to metal grate
Exterior wall with plaster damage, exposed brickwork, and crumbling plaster at the foundation area
P.S. Unfortunately, the specialist store was out of base coat paint. At the DIY store, they wanted to sell me wood protective paint instead of base coat paint. I insisted on the base coat paint because I couldn’t imagine that wood and plaster have the same properties... Do you have any information about this?
Nordlys
15 Apr 2017 19:08
Repair it, let it cure and dry thoroughly, then apply the exterior paint. It looks to me like frost may have caused some damage there at some point. Karsten
mibe2500
30 Jun 2017 21:58
Base plaster: Observe the maximum depth below ground level. Do not forget the base waterproofing. Only then apply the appropriate paint.
