ᐅ Rental House – Prefabricated House or Traditional Brick Construction
Created on: 13 Feb 2017 13:51
Dimma
We want to build a house to rent out. Nothing "fancy," just two apartments stacked on top of each other (each about 90 sqm (970 sq ft)), with two garages...
We are currently undecided about what makes more sense: a prefabricated house or a conventional brick-built house?
We have found that there is probably not much difference in price.
It should be a turnkey house. Financing is not an issue due to an inheritance, and the building plot is already available.
Can anyone offer some guidance or points to consider?
We are complete beginners when it comes to building a house, and the construction companies can say a lot.
What should we pay attention to?
Dimma schrieb:
One more silly question... a guest toilet in a 3-4 room apartment? Definitely for a certain size. In my opinion, a separate bathroom belongs to a 4-room apartment.
Regarding suggestions: just check Pinterest or Google Images, you will find suitable floor plans there.
Here, newly built apartments always have a guest toilet, even if they are only 70cm (27.5 inches) in size. I believe future tenants simply expect this in a new apartment, as well as a basement. How profitable is it actually to build a multi-family house? Such a building costs around 500,000 euros without the land. Don’t you have to rent it out for ages to recover the construction costs? Isn’t an existing property much more profitable in that case?
Sabine
Sabine
When I look at the prices for not too old existing properties here and consider that the building plot is already available, I think that building your own house (through a builder) is not the worst idea. Of course, it takes ages to recoup the construction costs, but the value of the house remains. At the current interest rates, there isn’t much alternative...
Dimma schrieb:
Websites where I can look at reasonably pre-designed apartments of that size? Just to get some ideas about what makes sense?Try searching online (for example, "two-family house floor plan"), Pinterest, as well as real estate listings on platforms like Immoscout and others, or prefab house brochures (look for the bungalow section because of the single-story design). Bathrooms are rarely smaller than 5 square meters (54 square feet), kitchens and children’s rooms start at about 10 square meters (108 square feet), bedrooms from 14 square meters (150 square feet), and living rooms alone from 25 square meters (270 square feet), more if combined with a dining area. Except for bathrooms, hardly any room is narrower than 2 meters (6.5 feet). Even in children’s rooms, you want to be able to place the bed lengthwise or widthwise. Comfortable passage widths start from 90 cm (35 inches), which is also roughly the side length of a shower enclosure. Even guest toilets or cleaning rooms / pantries are usually about 2 square meters (22 square feet). Check apartment listings online, as they often include floor plans (almost always for condominiums), and then visit in person. This way, you get both the plan and the real-life comparison.
RobsonMKK schrieb:
Bungalows are useless; they have a utility room and no staircase.It’s nice that you’re directly coming from Schlauberg. There are more and more bungalow designs for people without children (but with a home office). At around 90 cm (35 inches), the utility room often has roughly the same size and location as a staircase. Of course, it’s not suitable for exact one-to-one copying, but it’s enough as a reference.
