ᐅ Renovating a Basement in an Older Building
Created on: 30 Oct 2016 19:53
esteban51
esteban51
30 Oct 2016 19:53
I want to renovate the interior of an old building’s basement. The basement consists of a granite stone plinth with a Prussian vault wall above it. I plan to level the exterior walls with a lime plaster and then install calcium silicate boards on top. Since the basement is still somewhat damp, I think this would be the best option. As the entire house will be insulated internally, the basement ceiling does not need insulation; however, I would like to try to thermally insulate the vault wall or insulate it at the junction with the exterior wall. I’m not sure how to proceed with this. Do you have any ideas? And is exterior wall insulation using calcium silicate combined with lime a good solution?
Thank you very much!
Sebastian
JP-Bauherr
31 Oct 2016 08:56
Don’t forget to install a perimeter drainage system with gravel around the foundation, then add a waterproof membrane around the basement. That way, it will stay dry. 🙂
esteban51
1 Nov 2016 22:48
Thanks for the hint, but waterproofing measures have already been carried out earlier 🙂 Does really no one know anything about the ceiling cappings?
Nofret2 Nov 2016 08:27
.. Well, if the basement is still damp, it should be improved again, otherwise you will have mold behind the interior insulation – which won’t make things any better.
