ᐅ Remove green moss from WPC fence and natural stone patio tiles
Created on: 14 Apr 2024 19:40
lolerloler
lolerloler
14 Apr 2024 19:40
Good evening,
I have quite a lot of green moss on the WPC fence and natural stone terrace slabs. What would you recommend as the best treatment, preferably avoiding strong chemicals (if not, the options seem overwhelming). Thank you very much!
nordanney
14 Apr 2024 19:58
lolerloler schrieb:
What would you recommend best if possible to avoid chemical cleaners (if not, the options are overwhelming).
Baking soda and hot water. Let it sit overnight. If that doesn’t help, then go for the chemical cleaner. Otherwise, of course, mechanical cleaning with a pressure washer.
14 Apr 2024 22:15
I use the back side of a garden tool (hand cultivator) to scrape off thick clumps. Or do you mean more the algae buildup?
Musketier15 Apr 2024 08:25
This spring, I cleaned the terrace and path using a pressure washer with a surface cleaner. It works great and looks like new. With WPC (wood-plastic composite), you need to check if this method is suitable.
lolerloler
30 Apr 2024 11:14
Hello everyone. The problem with the pressure washer is that the panels rest on gravel, and I think the gravel will get washed out of the joints if I use the pressure washer here.
Has anyone already cleaned WPC fences with a pressure washer?
PS: I actually do have a surface cleaner attachment for the pressure washer.
