ᐅ Reliable manufacturer of vinyl flooring sought for long-term cooperation
Created on: 11 Oct 2025 08:29
rtd2912
rtd2912
11 Oct 2025 08:29
we have a condominium with approximately 100 m² (1,080 sq ft) of floor space and would like to replace the old laminate flooring with wood-look vinyl.
Since we expect a cost of around 50 euros per m² (about $50 per 10.8 sq ft), and the open-plan kitchen is also due for renovation during this process, we would like to spread the work room by room over two to three years due to budget constraints. Therefore, we are wondering if there are any vinyl flooring manufacturers that reliably offer the same products over several years. The vinyl should be consistent throughout the entire apartment. Storing extra material in advance is difficult for us because the basement is damp. It would also be inconvenient if a few pieces end up missing due to cutting waste, etc.
Does anyone have experience with manufacturers who can supply the same products over an extended period?
Thank you very much.
Jesse Custer
11 Oct 2025 09:12
Let’s put it another way:
I don’t know a single manufacturer who, for one reason or another, hasn’t discontinued something I sourced from them overnight or could do so.
Therefore, in my opinion, this is not feasible.
Conclusion: buy everything complete and store it somewhere in the apartment.
kbt09
11 Oct 2025 11:51
I agree with @Jesse Custer on this... plus, you have everything from the same batch.
nordanney
11 Oct 2025 12:21
rtd2912 schrieb:
Since we are estimating 50 euros per square meter (approximately 5.1 USD per square foot),
Then look for high-quality material sold as clearance stock for 25 euros (about 2.6 USD per square foot). Double the quantity for the same price. That way, you can finish the entire apartment.
KlaRa14 Oct 2025 22:23
The background of the initial question is difficult for a flooring technology expert to understand!
If a floor plan is available for different rooms, and the pattern repeat (or offset) as well as the installation direction are known, then the amount of flooring material to be installed can be accurately calculated. There is no need for reordering material years later.
Depending on the angle and intensity of the light, the color tone of the decorative layer will change over time, even with sufficient UV resistance—though to varying degrees. Any new "patch piece," whether stored in the basement for years or purchased as a new production batch, will always show some color variation. This can also occur between different production batches.
Using a gray scale, the standard-acceptable differences in perception will not please any homeowner. In other words, the color differences between existing and new flooring can be significant—and yet still be within acceptable limits.
Have a trained floor layer (ideally using the software "Optifloor") calculate how many square meters you need to buy for your property. Add 2 m² (about 22 sq ft) for possible local repairs or damage—that is absolutely sufficient.
Especially in these uncertain times, who knows whether your trusted manufacturer and supplier will still be on the market tomorrow?
Best regards to all, KlaRa
nordanney
14 Oct 2025 22:38
KlaRa schrieb:
The background of the initial question is just not clear to a flooring technology expert!
It’s simple. If I have one euro per week for sweets, I can only buy 5 candy shells. If I want to eat more, I have to wait a week.
The same goes for the original poster. Just no money to immediately buy enough square meters (sqm) (square feet). Too simple a reason? 😉
