ᐅ Issues / Load-Bearing Capacity of Attic / Existing Structural Assessment / Evaluation
Created on: 14 Nov 2014 20:42
rennem01
rennem01
14 Nov 2014 20:42
Hello to all forum members,
I have been a silent reader of this forum for quite some time and have already found answers to several of my questions here. Now I have a question and hope someone can help me before I contact our structural engineer: We built a staggered shed roof house (KFW70 standard) in 2013 and moved in at the beginning of 2014. I am now considering installing a substructure made of 50x30 mm (2x1 inch) squared timbers in the large shed roof and laying tongue-and-groove boards about 22 mm (7/8 inch) thick on top, so that we can use the attic as storage space. The attic is insulated, with a vapor barrier underneath the insulation, and below that the typical assembly of battens and drywall. I have a problem with our structural engineering documents: Either I do not understand how to read them correctly, or there is a missing specification—the information about the maximum load or weight allowed on our attic. I would appreciate if an expert could weigh in on whether I am overlooking something or if this detail is indeed missing.
Greetings from Frankenthal,
Marco
BratacDD
14 Nov 2014 21:52
Hello Marco,
The information you are looking for is not included, but it doesn’t necessarily need to be. I assume you want to install an additional ceiling at the level of position D2. Is that correct? The duplications are probably only calculated for the drywall ceiling, or I assume they are not calculated at all since nothing would protrude through the OSB panels on the underside. As far as I can tell, the rafters still have enough reserve capacity. So if you want to do this, I would have a structural engineer calculate how to reinforce the positions so they can support a load of 200 kg/m² (41 lb/ft²).
Regards,
Ronny
rennem01
15 Nov 2014 13:18
Hi Ronny,
ok, thanks for the information and assessment. That’s correct, it is a plank flooring on level D2 that I want to install. I will contact our structural engineer to find out what load can currently be applied there. That might even be sufficient.
Thanks again.
Regards,
Marco
