ᐅ Plastering the ceiling
Created on: 13 Jan 2016 14:00
pulsar86
pulsar86
13 Jan 2016 14:00
I would like to know the best way to plaster the type of ceiling shown in the attached picture, or which material to use.
My initial thought was to use Rotband, but I’m not sure if that’s the right choice.
Does anyone have experience with this?
Thank you,
Regards, Patrick
Abgeplatzter Putz an Innenwand mit sichtbaren Schichten und Rissen.
wpic13 Jan 2016 14:20
This is a very unusual ceiling construction for the German region. It is more similar to the Austrian "Dippeltram ceiling." You cannot plaster the underside of the beams directly. First, you need to install a plaster base that also compensates for unevenness, for example, wood wool panels (Heraklith), reed mats, ribbed expanded metal, or tiled wire mesh (brand "Stauss"). Using just a reinforcing mesh alone will not be sufficient.
If the ceiling vibrates, meaning it is either undersized or has too much load, you should expect cracks in the plaster. The most suitable plaster would be a gypsum-lime or gypsum plaster—also the unavoidable "Rotband." Properly plastering a ceiling is no easy task—perhaps you should leave this to a professional tradesperson. The old plaster must definitely be completely removed.
