ᐅ Planning the Floor Plan for a Bungalow
Created on: 4 Jan 2015 23:13
Bamue89
I have been working on a floor plan for a few weeks now and would like to compare it with your experiences in the hope of improving some aspects. The room dimensions are not set in stone and can of course be adjusted (especially the heating/laundry room and bathroom).
About the basics
We are planning a bungalow in the New England style. The size will be about 180 m2 (1,938 sq ft). One full floor without a basement so far. Minimal roof pitch. The main entrance is on the east side, accessed via an adjoining veranda, with the terrace and living room on the west, due to the characteristics of the plot. Since we’re not necessarily sun seekers, the south side is rather underused, but hopefully that won’t be a problem because of the low roof pitch. Solar thermal tube collectors are planned for the southern roof surface.
I’m still unsure about the size of the integrated garage, as well as the room dimensions overall. It’s difficult for me to assess whether everything will be practical for everyday use. We are planning to have two children in the future, each with a room about 14 m2 (150 sq ft) and a small children’s bathroom with a shower. Until then, these two rooms will be used as guest and work/hobby rooms. The fireplace room can serve as a guest room if necessary. I know it’s a walk-through room, but as mentioned, that would only be a temporary solution. The floor plan is based on zoning, which I hope is visible. I have planned floor-to-ceiling sliding glass doors in the dining room to extend the space during summer.
The size of the heating room is probably debatable. Since we plan to install a gas boiler with a buffer tank, space might be tight. I had the idea to initially combine the laundry and heating rooms as one and install a partition wall later after installation. The storage room (just a small storage area) could also benefit from a better location due to the possible heat generation.
The attached rough sketch is just a draft, drawn to 1:100 scale. I hope you can get something from it; otherwise, I can make a clearer drawing. I also have a digital 2D draft, but unfortunately without dimensions and it’s not quite up to date. Please don’t be too harsh on my limited expertise in building planning—I’m hoping for constructive suggestions for improvement.
Looking forward to your opinions! Thanks
Skizzenhafter Grundriss eines Hauses mit Wohnzimmer, Küche, Bad, Schlafzimmer, Terrasse und Garage.
Bamue89
16 Jan 2015 15:30
I just had a good idea to improve the mouse pathway to the private area and am currently working on it.
kbt09
16 Jan 2015 16:44
I’m afraid your master bathroom layout won’t work as planned. A 100cm by 100cm (39in by 39in) shower and a bathtub about 80cm (31.5in) wide leave only 60cm (24in) for a walkway. That’s not even enough space for the shower door to open outward. The toilet area will feel very cramped.
Having 163cm (64in) for two rows of cabinets won’t work well either. Even if you only install the cabinet boxes without doors (I have the same setup in my closet), the cabinets themselves will be at least 112cm (44in) deep, leaving just 41cm (16in) for passage, and these are all unfinished structural dimensions.
The guest toilet is also quite tight.
The master bedroom is about 288cm (113in) wide, unfinished. With a standard bed, you’ll have only about 70 to 73cm (28 to 29in) of clearance at the foot of the bed.
Overall, the spaces feel quite cramped and awkward—sorry 😎
Bamue89
16 Jan 2015 17:20
Yes, that’s correct. The depth of the bedroom can probably only be adjusted by the size of the walk-in closet. One could do without a built-in wardrobe system. The furnishings are just an example. I will probably need to revise the size of the kids’ bathroom. We’ll see.
kbt09
16 Jan 2015 17:22
Better .. 😉 ... nice PDF file names.
But the walls ...
Just a question .. are the children still very young?
Bamue89
16 Jan 2015 17:24
We don’t have any yet, but they are planned ^^ Is this the wrong answer now XD
kbt09
16 Jan 2015 17:43
Yes 😉 ... no, of course not. I just wanted to check if separating the parents' and children's sleeping areas might be an option.
