ᐅ Photovoltaic system 46562, 8.88 kWp, €13,414.98
Created on: 3 May 2022 13:50
Malz1902
we are planning to install a photovoltaic system on our roof.
Today I received the first offer: 24 modules at 370 Wp each, totaling 8.88 kWp.
The price including installation with scaffolding and connection is 13,414.98 € net.
Modules: Solarwatt Panel classic H 1.2
Inverter: Kostal Plenticore plus 7.0
Attached are some pictures of our roof. The orientation is southeast.
What do you think of this offer?
Our electricity consumption is about 7000 kWh (heat pump for heating/cooling, hot water, and other household uses).
Two-story brick house with dark tiled roof behind a gray panel fence and gabion pillar.
Sloped roof with dark tiles, satellite dish, brick facade and window.
Roof of a brick house with brown roof tiles, chimney and roller shutter windows.
Roof of a house with gray slate tiles, chimney, window, green leaves in the foreground.
Roof of a house with gray tiles, chimney, satellite dish and window.
Two-story houses with blue and red tiled roofs, satellite dish, fence and garden plants.
netuser
4 May 2022 10:06
Andre77 schrieb:
Scaffolding might not always be necessary. For me, the workers just climbed onto the roof using a ladder.
By now, scaffolding is mandatory. Companies or workers won’t go onto the roof above a certain height and roof structure without it, due to fall protection regulations and so on. In case of an accident or similar, it becomes a much bigger issue for insurance purposes.
Andre77
4 May 2022 11:41
@netuser
What do you mean by "in the meantime"? My eaves height is also just about 3m (10 feet), maybe that was the reason. The installation was done 2 years ago.
Tolentino4 May 2022 13:23
A contractor told me they do it using a lifting platform. I have no idea if that is allowed or not.
Since I recently saw in the neighborhood of my condominium how the facade of a multi-family building was renovated by rope climbers, I also think it is not prohibited, but it requires special safety measures.
WilderSueden
4 May 2022 13:59
Rope access involves working at height and follows a completely different set of regulations. I spent some time setting climbing routes in our climbing gym, and there the same rules apply. You need a working rope plus redundancy, redundant anchor points, and devices that lock unless you press a button. With all the equipment and special training required, it usually doesn’t end up being cheaper than scaffolding if you’re just working on a one- to two-story house.
If you go onto the roof without scaffolding and safety netting, you need fall protection with a rope system. This can also work with an aerial work platform, provided there is a secure anchor point.
Malz1902
4 May 2022 14:15
Roof approximately 3 m (10 feet) wide x 6.97 m (23 feet) long with a pitch of 45°
Dormer approximately 2 m (6.5 feet) wide x 2.31 m (7.6 feet) long with a pitch of 40°
Through the dormer, the view is naturally great, that’s true. Adding one on the other side of the roof is also an option, at least covering half of it.
