ᐅ Moisture or Water Stains in the Basement After Heating Cycle
Created on: 26 Oct 2022 13:51
clausen77
clausen77
26 Oct 2022 13:51
We have now completed the screed heating protocol, and according to the tiler, the screed is well dried.
However, during the heating phase, water stains appeared on the walls in two larger rooms in the basement only (see photos).
Our site manager now suggests setting up drying equipment. Is this the right approach? I would also like to understand why the stains appeared at all (only in the basement, not on the ground or upper floors). Was it due to improper execution of the heating program? There was a dehumidifier in one of the rooms, but in my opinion, it was emptied too infrequently (whenever I was there, the container was full and I emptied it).
The basement itself is constructed as a waterproof concrete structure ("white tank") and the seals looked good. However, it rained several times during the heating phase.
Thank you very much for your advice.
Two round wall openings near the floor, yellow machine with wheels and cables on the floor.
Unfinished corner of the room with five round wall holes at the bottom of the wall; cable visible in the right hole.
Corner of a damp room with cracked wall, water stains at the base and dark tiles.
White wall with moisture damage and peeling plaster at the bottom edge, green openings.
Wall corner with moisture marks, two round holes, dark floor tiles.
Corner of an unfinished room: white walls, moisture at the bottom, two round wall openings.
KlaRa4 Nov 2022 14:05
Hello "Clausen77".
Some issues in construction technology cannot be resolved easily, or only with considerable effort.
I am writing this to you as an expert in the field!
In the case you described, I would indeed follow the site manager's advice and wait to see how the situation develops on the lower wall surfaces.
It is definitely not due to a "wrong heating program."
Whether it makes sense to use forced drying equipment depends on the indoor humidity levels you measure at a given room temperature.
A "white tank" (watertight concrete structure) does not mean it is vapor-proof against water vapor; it means it is sealed against liquid water.
What is visible in the photos is by no means dramatic.
However, the situation should be monitored carefully without causing unnecessary alarm.
Regards, KlaRa
clausen77
4 Nov 2022 15:00
Hello KlaRa, thank you very much for your assessment and for taking the time to respond so thoroughly. That already reassures me a bit.
I will continue to report on any further developments regarding the screed.
