ᐅ Modern single-family home designed by an architect in southern Germany
Created on: 14 Aug 2020 09:58
Martial.white
Plot size: 701 m² (8,435 sq ft)
Slope: None
Floor Area Ratio: 0.4
Building envelope: Marked in the current plan as “brackets”; rotation of the building envelope has been tentatively approved by the planning authority
Number of parking spaces: Garage within the garage building envelope (existing and to be retained from 1980, 6.48 m x 4.48 m (21 ft 3 in x 14 ft 8 in))
Number of floors: 2.5
Roof style: Gable roof, 45°–55° pitch
Architectural style:
Orientation:
Maximum heights/limits: Top of roof = 6.3 m (20 ft 8 in); ridge height 12.0 m (39 ft 4 in)
Further requirements:
Architectural style, roof type, building type: Modern single-family house.
Basement = Yes. Number of floors =
Number of occupants, ages: 2 adults in their early 30s and 2 small children (3 years & 0.5 years)
Space requirements on ground floor and upper floor:
Office: Home office—currently 5 days a week; after Covid likely 4 days a week
Overnight guests per year: So far, no regular overnight guests.
Open architecture, modern design, open kitchen, preferably with a cooking island
Number of dining seats: When the whole family is present, 12 adults and 4 children
Fireplace: No
Music/stereo wall: Hi-fi only; TV will be located in the attic level (top floor)
Roof terrace: Yes.
Technology: Controlled mechanical ventilation, KNX smart home system
Garage, carport: Garage already exists
Utility garden, greenhouse: Vegetable garden planned but manageable in size for two children and one full-time earner
Designer: Architect
What do you especially like? Spacious entrance area despite the small building envelope. Large living/kitchen area
What do you dislike? The floor plans for ground floor and first floor have already been revised once; this version 2 now meets our expectations. The attic layout could still be improved. It is planned to be used as a guest room and TV room.
My architect strongly favors building to the highest energy efficiency standards. The energy consultant believes KfW 55 standard is just achievable – I want to avoid excessive insulation because otherwise the living space would shrink too much due to the very small building envelope. I would prefer KfW 55 standard, but I expect the planned photovoltaic system to compensate for the slightly higher energy consumption.
The floor height on the ground floor has been increased by one stair step (+1 step = about 30 cm (12 in)) after consultation with heating engineers due to the ventilation system. Plans are being updated accordingly. I am quite alone on this, as my architect has never designed a house with controlled mechanical ventilation before.
Architect’s cost estimate: 690,000 €
Personal maximum budget for house including fixtures and fittings: See architect’s cost estimate
Preferred heating system: Air-to-water heat pump or ground-source heat pump (mainly due to noise concerns in the garden and slightly better cooling performance via underfloor heating). Payback on ground-source heat pump likely won’t occur within my lifetime.
If you had to make compromises, on which details or extensions
-could you compromise: Sun deck or the entire attic floor in an emergency.
-could not compromise: The landing staircase, even if it is not very space-efficient.
I believe we have created a good floor plan with the architect. I hope you can review the plans with fresh eyes to prevent me from overlooking possible issues. I also welcome ideas for bathroom and kitchen layouts.
With that, I now venture from quietly reading to stepping into the lion’s den. I will provide scaled plans with dimensions after receipt if desired.
Slope: None
Orientation:
Fireplace: No
Roof terrace: Yes.
Designer: Architect
Martial.white schrieb:
Move the master bedroom upstairsDo you really want to have to climb two flights of stairs to get to the bedroom? I would also prefer to put the children’s rooms all the way upstairs. Then, when they eventually move out, you simply won’t use the top floor anymore. Leaving the middle floor empty seems less than ideal to me.G
gtgeorge7930 Aug 2020 22:15Are there any updates on your planning? Have you made further progress?
Martial.white3 Sep 2020 08:57We have developed the details further. Every change leads to a cascade of subsequent necessary adjustments.
We increased the ceiling height on the ground floor by 20 cm (8 inches).
After the discussion with the kitchen planner, we slightly enlarged the kitchen corner and further developed the bathroom layout.
All in all, aside from adjusting the ceiling height, there are no major changes.
Next week, we will submit the building permit / planning permission application.
Please keep your fingers crossed.
gtgeorge793 Sep 2020 10:45Martial.white schrieb:
We have made detailed improvements. Every change leads to a chain reaction of further necessary adjustments.
We slightly enlarged the kitchen area after consulting with the kitchen designer and further developed the bathroom layout.
All in all, apart from adjusting the ceiling height, nothing major.
We will submit the building permit / planning permission application next week.
Please keep your fingers crossed Could you show us the current plans?M
Martial.white3 Sep 2020 12:29@gtgeorge79 The current plans don’t show this; compared to the original post, these are changes in the range of centimeters (inches). Mainly, they allow for extra space to accommodate potential deviations during construction.
The ceiling height is only indicated in the plans by an additional step on the staircase from the ground floor to the upper floor.
The additional information in the updated plans is really minimal. If you have a specific question, I might be able to answer it directly. (Private messages are not available yet).
gtgeorge793 Sep 2020 12:36OK, I understand. I thought the plans were well done and would have found it very interesting to see how they further developed. I am currently reviewing good floor plans for my project. I find yours inspiring because it stands out from the typical, conventional designs.
