ᐅ Malm Nightstand Plastic Parts Break Easily – What Can Be Done?
Created on: 4 Jun 2022 08:37
gejana51Hello everyone,
I’ve been using the Malm bedside table from Ikea for a while and am generally satisfied, but the plastic parts that guide and lock the drawers break way too quickly—sometimes after just a few months or under slightly heavier use. This is frustrating because the drawer then sticks or partially falls out.
Has anyone else had similar experiences? More importantly, what can be done to improve the durability of these plastic parts, or is it only possible to replace the entire drawer slide? Are there alternative parts that can be installed, or tricks to reduce the strain? I’d rather not have to buy completely new units repeatedly. Thanks for any helpful advice!
gejana51 schrieb:
the plastic components that guide and lock the drawers break way too quickly for meThat sounds like a material issue or overloading. But before pointing out that Ikea materials are often on the more affordable side: How exactly are you using the drawers? Are they regularly overloaded or perhaps loaded incorrectly?
It would be helpful to understand the usage pattern in detail, because without an objective analysis, we might miss the real problem. Alternative parts might also be of higher quality, but do they fit without modifications? And what about warranty or goodwill coverage if parts break under normal use?
gejana51 schrieb:
The plastic parts that guide and lock the drawers break too quickly for meIn addition to faso31’s question: It would be important to know what type of plastic was used here and the environment where the nightstand is placed – for example, whether it is frequently exposed to moisture or temperature fluctuations.
The slides of Malm drawers are usually made from ABS or acrylic, which can become brittle if they are frequently stressed or improperly installed. One possible reason for premature breaking is the installation: Are the slides twisted or subjected to uneven pressure when inserting the drawer?
One recommended step would be to inspect the slides carefully when removing the drawer and possibly lubricate them lightly with silicone spray to reduce friction. It is also worth considering the weight of the contents – boxes with books, for example, require more durable components.
I am also interested in whether the drawers are usually fully extended regularly or only partially. The locking mechanism is sensitive to incorrect handling.
Simple solution: Buy replacement parts directly from Ikea. They are inexpensive and perfectly matched to the bedside table.
Alternatively, you can minimize the load on the drawers by not overloading them or by distributing weight evenly.
Otherwise, the only option is to carefully open and close the drawers. Do not use force.
Regarding durability, plastic components do have a limited lifespan, especially in affordable furniture such as the Malm nightstand, which is designed for normal everyday use.
If the plastic parts break without being overloaded, there might be a quality defect. I recommend keeping the parts if possible and contacting Ikea to request a replacement after consultation – sometimes goodwill solutions are offered.
For self-repair, reinforcing felt or rubber strips can be applied to the contact surfaces to reduce friction. Using assembly adhesive – applied carefully – at stress-prone points can also provide reinforcement, but caution is needed to avoid limiting the function.
RonJarrett6 Jun 2022 14:02gejana51 schrieb:
The plastic parts that guide and lock the drawers in place break too quickly for meA structured solution to this problem mainly requires focusing on the materials used and their load limits:
1. Identify the exact point of failure: Is it the drawer guide or the locking mechanism?
2. Check if the furniture is assembled correctly. Flat-pack furniture often has critical assembly points, where incorrect installation can lead to instability.
3. Consider using alternative guide rails (e.g., metal guides) as an upgrade, which especially improves durability.
4. Document the load and usage conditions for potential warranty claims.
Another approach is to systematically clean and lubricate the guide components to reduce mechanical stress.
