I would like to remove a wall in my house to enlarge the living room and connect it to the kitchen. I would like to know how much I should expect to spend and what I can or should do myself.
This mainly depends on whether the wall is load-bearing or not. If it is, I would need to install a beam (right?), which I definitely couldn’t do on my own. Simply removing a non-load-bearing wall wouldn’t be a problem.
My question is, how do I find out if the wall is load-bearing or not? Who can tell me this? Do I need to consult a structural engineer?
K.Brodbeck16 Jan 2014 14:06sparhawk schrieb:
I would like to remove a wall in my house to enlarge the living room and connect it with the kitchen. I would like to know what costs I should expect and what I can or should do myself.
This obviously depends primarily on whether the wall is load-bearing or not. If it is, then I would need to install a beam (right?), which I definitely couldn’t do on my own. Removing a non-load-bearing wall would be no problem.
The question is, how do I find out if the wall is load-bearing or not? Who can tell me? Do I need to consult a structural engineer?Hello,
yes, consulting a structural engineer is the right approach! They might also be able to provide an estimate of the costs. However, they will need basic information about the structural design of your house; otherwise, they won’t be able to help you much!
K.Brodbeck
b.schlosser28 Feb 2014 17:26Always consult a structural engineer! Otherwise, it can turn out badly. If it is a load-bearing wall, steel beams must be installed. Depending on the length, these can easily weigh 100 kg (220 lbs) or more, but can be installed independently with help. So, ask experts for structural advice and do not attempt the work alone.
