ᐅ Lift-and-slide door or two double French doors for KFW55 standard
Created on: 11 Aug 2021 09:14
Pacc666
we are planning to install a lift-and-slide door in the living room instead of two double doors side by side, each with two panels that open inward (I don’t know the exact term right now).
In the living room, these are the only windows, and on the ground floor there is only one more window in the open kitchen.
What are the advantages and disadvantages of a lift-and-slide door compared to two double doors, especially in relation to a KfW55 building standard?
hampshire11 Aug 2021 16:05A good alternative would also be folding glass walls.
Advantages:
Advantages:
- Complete opening across the entire width
- Higher cost
- Some space needed for opening and closing (ours fold outward)
- Risk of pinching fingers (might be too risky for some parents)
Bertram10011 Aug 2021 16:35I have a lift-and-slide door with a sliding section that is 2.50 meters (8 feet 2 inches) long and floor-to-ceiling. I would much rather have a regular door and the rest as a lift-and-slide door. I find it annoying to always have to open the sliding door. If a regular door is also 5000 euros cheaper, then I really don’t see any reason to choose the lift-and-slide door at all. Doors don’t look bad anyway.
Pacc666 schrieb:
It will just be a lift-and-slide door
the width will be about 5m (16.4 ft), so 2.5m (8.2 ft) per panel I have exactly that—a 5m (16.4 ft) wide triple-glazed lift-and-slide door divided in the middle. And I have several children.
I’m happy to share my experience:
Tolentino schrieb:
Very heavy at a “worthwhile” size (kids) Tolentino schrieb:
Kids, well, you have to see. ypg schrieb:
Reconsider the disadvantages: children can’t push the heavy panels We moved in when our middle child started school, and this child, who had never used a lift-and-slide door before, was able to open it easily after just one explanation. Adults and older children compensate for lack of technique with strength. Therefore, I assume even a 5-year-old can open the door with the right technique.
If you can wait a few more years, I can tell you when my currently 2-year-old opens it by herself 😉
Tolentino schrieb:
At an age when they can’t manage it, it’s probably a “feature”; at least I wouldn’t want a toddler alone with it. Only partially true—a simple two-word command like “door open” is enough, and the older siblings willingly open the sliding door for the little one. Flipping the lever to lower the door works once the kids can reach the lever.
Tolentino schrieb:
Pinch hazard, since you have to watch other spots (at the bottom). That’s something little kids usually haven’t learned yet... None of my children have ever gotten pinched, not even the 2-year-old when the older siblings close the sliding door carelessly.
I would choose the lift-and-slide door again anytime.
