ᐅ Liaplan – does anyone know this type of stone?
Created on: 14 Jun 2016 22:54
McEgg
Our currently preferred general contractor offers the Liaplan Ultra 09 as the standard exterior wall, with a wall thickness of 36.5cm (14.4 inches). Can anyone share their experience with this block? I haven’t found any reviews.
Here are the specifications of the block:
Wall thickness cm 36.5
Block type Standard block
Length cm 24.8
Height cm 24.8
Strength class HBL 2
Density class 0.50
Permissible wall compressive stress MN/m2 0.4
Thermal conductivity W/mK 0.09
U-value W/m2K 0.23
Sound insulation rating R´w-BAU (dB) 51
Thermal storage capacity kJ/m2K 182
For a small additional cost, I could get the Liaplan Ultra 08:
Length cm 24.8
Height cm 24.8
Density class 0.45
Thermal conductivity W/mK 0.08
U-value W/m2K 0.21
Sound insulation rating R´w-BAU (dB) 50
Thermal storage capacity kJ/m2K 164
Could anyone provide some input on these? It’s especially important to me that I don’t hear anything from outside once inside the house. For a significantly higher price, I could also get something completely different (e.g., sand-lime brick with external thermal insulation system).
Bauexperte
17 Jun 2016 10:28
I am familiar with expanded clay aggregate and have worked with precast wall panels made from this material in earlier years. The U-value mentioned in the first post corresponds to the current standard and can also be found with aerated concrete as well as perforated bricks. Therefore, I see no reason why the use of expanded clay aggregate in house construction should be opposed.
Regards, Bauexperte
McEgg17 Jun 2016 10:39
OK, thanks. So basically, I can’t really go wrong with the block. It really just comes down to personal preference. As I said, having peace and quiet is important to me. If you say that with a 36.5cm (14.4 inches) block you can’t hear anything (unless you have poor doors or windows), then that’s fine.
Calcium silicate bricks are heavier, so they are probably better for interior walls if you don’t want to hear everything from the next room.
On the other hand, only family members live in the house. So I think you’re less bothered by noise compared to having strangers around.
I just need to decide whether I prefer calcium silicate bricks with a polystyrene exterior insulation, or cavity blocks where the polystyrene is inside the cavities...
