ᐅ KALLAX Minimum Panel Size – Any Tips?
Created on: 18 Feb 2024 09:17
KIBLA
I am planning to get an IKEA KALLAX shelf to store my vinyl record collection in an organized and space-saving way. I have a question: What is the minimum size the KALLAX should be to store records as safely, neatly, and accessibly as possible?
I know that a 4x4 unit is often recommended, but what about smaller or custom-sized versions? Are there any tips for using the available space as efficiently as possible without damaging the records or compressing them too much?
Maybe there are also recommendations for additional components, inserts, or other tricks to get the most out of the KALLAX?
Thanks for your experiences and advice!
SUBEN60
19 Feb 2024 07:32
Good morning,
KIBLA, to answer your question objectively: A KALLAX shelf with 4x4 compartments offers you about 16 sections with typical internal dimensions of 33x33 cm (13x13 inches), which are ideal for LPs.
Since each LP is on average 1-2 cm (0.4-0.8 inches) thick and you have around 200 records, you need at least 200 to 400 cm (79-157 inches) of shelf width. A 4x4 shelf has approximately 33 cm (13 inches) of width and depth per compartment, so you can comfortably store 30-35 LPs per section.
Smaller options (such as 2x4 or 2x2) would become too packed depending on the number of records, which would make handling difficult and could cause permanent damage to the albums.
Additional tip: Use record supports or holders inside the shelf to evenly distribute pressure and prevent tipping. Regularly checking the storage conditions is also advisable.
Jukin schrieb:
A 4x4 shelf provides enough space so the records aren’t packed too tightly, which helps preserve their condition
This is an important point because too much compression can damage the record spines.
Therefore, I clearly recommend a 4x4 KALLAX as the minimum size for your collection.
Paunon
19 Feb 2024 08:00
One more quick note:
If you really want to use the shelf flexibly, it’s worth considering adding shelves later. KALLAX units are easy to expand modularly.
So, you don’t have to buy the largest one right away; start with a 2x4 and add more as needed. But fitting 200 records will be tight.
meGreg
20 Feb 2024 16:19
I wanted to add:
If you equip the KALLAX with inserts or removable interior boxes, you can better adapt the compartments to your collection.
A vinyl enthusiast once recommended not to overfill the compartments but to store the records with some space between them and secure the records with sturdy bookends – this helps protect them in the long run.
So, don’t just think about the minimum size, but also about the organization within the shelf. This way, your vinyl rack becomes a truly happy place for your collection. 🙂
