ᐅ Removing KALLAX coating – ideas for repairing?
Created on: 23 Aug 2023 18:07
Joshpe
I have a small problem with my IKEA KALLAX shelf: the coating is peeling off in some areas. Since I don’t want to simply replace the shelf but try to repair the damaged spots, I’m looking for ideas on how to properly reattach or replace the peeling coating.
It’s important to me that the solution is reasonably durable and doesn’t peel off again quickly. If anyone has experience with specific adhesives, paints, or other materials that work well for this, I would really appreciate any tips.
Also, advice on how to best prepare the surface to ensure the repair holds well would be great.
Thanks in advance!
Joshpe
25 Aug 2023 19:02
First of all, many thanks to everyone who contributed such detailed input!
I will probably try contact adhesive, especially since the advice about better adhesion on the melamine backside makes sense.
One last point about the application:
- What is the best way to remove excess adhesive after bonding without damaging the surface?
- And is there a special technique for pressing it down so that the laminate lies flat and without air bubbles?
If anyone has experience with this, I would appreciate further tips.
TEBILO
25 Aug 2023 21:45
Joshpe schrieb:
How can you best remove excess glue after bonding without damaging the surface?
Here are a few tips:
Typically, contact adhesive is applied before joining and allowed to dry briefly. Any excess glue that becomes visible when pressing together should be wiped off immediately with a clean, lint-free cloth, ideally dampened with a mild solvent (e.g., thinner or a special adhesive remover) that does not damage the surface.
Be cautious, as melamine can become dull or cloudy if exposed to aggressive solvents. Always test first in an inconspicuous area!
For pressing, I recommend using a smooth roller or a flat wooden tool covered with a soft cloth to ensure even pressure and distribution, and to avoid air bubbles. A plastic squeegee can also be helpful.
For small areas, pressing by hand is often enough, followed by gently pushing any remaining air bubbles toward the edge with a squeegee or soft cloth.
Good luck!
Wesley
26 Aug 2023 10:33
Just a quick tip from me: I like to use an old bank card (or any plastic card) to press down and push out air bubbles. It works great and doesn’t scratch.
You can remove excess adhesive with a cotton pad and a little solvent before it dries. And please make sure to ventilate well because of the fumes.
Good luck, and hopefully the repair lasts a long time! 🙂
