Hello everyone, I am currently planning to mount my Kallax shelving unit on the wall as a “floating shelf,” meaning without visible legs or floor support. My question is which wall brackets are truly suitable to ensure the shelf is both securely held and visually appealing. I want to avoid the shelf eventually sagging or looking awkwardly suspended on the wall. Does anyone have experience with specific brackets or DIY solutions that work well for this? What type of anchors or screws would you recommend, especially if the Kallax shelf will bear some heavier loads? Are there any mounting options that can be installed invisibly so that no brackets or supports are visible from the outside? Looking forward to your tips and experiences!
FAZAR schrieb:
For example, so-called French cleats provide an invisible mounting system that allows the shelf to sit flush against the wall with minimal gaps while ensuring strong stability. That sounds very interesting, thank you for the detailed explanation!
Unfortunately, my wall is a standard drywall, so I definitely need to plan for reinforcements. I really like the idea of using an OSB board behind the shelf, since I was concerned that screws alone wouldn’t hold well in gypsum plasterboard.
Is there a rough recommendation for the dimensions of the OSB board? And how exactly should the connection between the OSB board and the shelf be made? I want to keep visible components to a minimum. I’d appreciate any additional tips if anyone else has experience with these types of substructures in drywall installations!
