ᐅ Is the foundation slab planned to be too deep?
Created on: 9 Mar 2019 16:29
M4rvin
Hi everyone,
I was at the construction site today and was a bit surprised at how deep our house is set... maybe the site is playing tricks on me, but I looked it up and most houses have the finished floor level about 30cm (12 inches) above ground level.
If the slab is really too low, that would explain why we have so much excavation. (The architect said during planning that there wouldn’t be much excavation and it could be spread on the property.)
Regards,
Marvin
Baustelle mit halbfertiger Wand aus weißen Steinen, zwei Arbeiter, Kranhaken, rote Generatorbox.
Baustelle mit zwei Arbeitern in Gelb an einer weißen Porenbetonwand; rechts Großgerät und pinke Dämmplatten.
Lumpi_LE
10 Mar 2019 07:59
You must have a plan, right? What does it say on it?
Müllerin
10 Mar 2019 08:16
seat88 schrieb:
Your wastewater pipe doesn’t end on top of the manhole cover .... but rather in the shaft, possibly 2m (6.5 ft) deep.
He’s probably more concerned about surface water... the rest can also be pumped if it doesn’t fit.
M4rvin10 Mar 2019 09:37
Yes, I am referring to surface water here. If the house is built into the terrain, water can flow into the house during rain.
Tego12
10 Mar 2019 09:48
Ground elevations can be very misleading to the naked eye... Just have them measured and compare them with the planning documents. Speculation won’t get you anywhere.
schubert7910 Mar 2019 10:44
According to the plan, your house is actually positioned lower compared to the street!
Lumpi_LE
10 Mar 2019 10:48
Where did he post a plan?
