ᐅ Is it possible to file a fictional claim for hail damage on the roof?
Created on: 19 Apr 2021 14:49
Hausi99
Hausi99
19 Apr 2021 14:49
Unfortunately, I cannot find a section for "roof" in the forum.
Maybe someone here can give me a tip.
Is it possible to settle a hail damage claim on a garage roof (metal roof) through the building insurance using an estimated cost process?
Similar to how hail damage to a car is handled?
That is, excluding VAT.
Or is an estimated cost settlement not allowed for claims through building insurance?
Since this is mainly a cosmetic issue, an estimated cost settlement is being considered.
The defect does not currently cause, nor is it expected to cause, any further damage in the future.
Thank you very much.
danixf
19 Apr 2021 15:39
Yes, it is possible. Having several detailed cost estimates makes it easier. It is also common, for example, after water damage, to bill separately. For instance, tiling might be invoiced for the insurance, while painting work is estimated.
As a general rule, the value is around 70% of the replacement cost. Google also shows some other examples on this topic.
guckuck2
19 Apr 2021 15:57
For a minor issue like damaged corrugated metal sheets, I would generally consider whether it’s worth filing a claim with the insurance. After two or three of these small damages, they quickly say goodbye, and then it gets expensive.
squier23
19 Apr 2021 23:43
The fictional damage settlement is currently uncertain in court, just as a side note.
HilfeHilfe
20 Apr 2021 06:13
guckuck2 schrieb:
For a minor issue like damaged corrugated metal sheets, I would generally consider whether it’s worth filing an insurance claim. After two or three small claims like that, they quickly say goodbye, and then it gets expensive.
Correct. With new insurance policies, you're increasingly losing tiered discounts per claim. So, a small claim often isn’t cost-effective.
guckuck2
20 Apr 2021 07:54
HilfeHilfe schrieb:
Correct. With new insurance policies, you increasingly lose cumulative no-claims discounts after a claim. So, a small claim often isn't worthwhile.
Worse is being canceled by the insurer. That doesn’t make finding a new policy any easier and usually leads to higher premiums. And without insurance, you can’t get a bank loan.
