ᐅ Insulation of a Single Room in a Barn
Created on: 13 Feb 2021 11:01
knappknacksliv
knappknacksliv
13 Feb 2021 11:01
I want to build a small office space inside a barn by partitioning it off.
For this, I plan to construct four walls using a stud frame. So, I won’t be attaching to any existing walls.
I want to use 12mm (1/2 inch) OSB panels on both the inside and outside, with plasterboard or gypsum fiberboard additionally on the inside, and mineral wool insulation in the cavity.
Now, regarding insulation, I’m unsure about vapor barriers and how to handle them.
I know I need some kind of barrier to prevent air from passing through.
But should it be a vapor-permeable membrane or a “regular,” airtight foil?
And should the barrier be placed on the inside, outside, or both?
It’s worth mentioning that the space won’t be used daily.
It will only be heated every few days on weekends. It’s not for continuous use. So, the solution should be cost-effective and balanced in relation to the expenses. If there is a reasonably good solution that is much less complicated but works satisfactorily, that would be perfectly fine for me.
Thanks in advance
hampshire
13 Feb 2021 11:25
Build the interior space of the barn using log cabin construction techniques and install a wood-burning stove. The chimney should pass through two roof layers. The ceiling is quite high, which should ensure excellent draft.
icandoit
13 Feb 2021 13:39
Should there also be a ceiling installed?
Windows and door?
Wood stud frame? Inside, instead of the OSB, use a vapor barrier. The drywall is sufficient there.
Wood moisture content max. 20%.
knappknacksliv
13 Feb 2021 14:15
icandoit schrieb:
Should there also be a ceiling?
Windows and door?
Wood studs? Inside, instead of OSB, a vapor barrier. The drywall is sufficient.
Wood maximum 20% moisture content.
Yes, wood studs. With a ceiling and even a floor (I haven’t paved the spot where the unit will be placed).
I have a standard side door ready.
I’m still unsure about windows.
So, a vapor barrier on the inside and nothing on the outside except OSB?
icandoit
13 Feb 2021 15:25
How is the floor structure planned?
knappknacksliv
13 Feb 2021 15:37
Since there is still an old pit underneath in some areas and the rest of the ground is slightly higher, the structure is more or less raised on supports. So there is air underneath the floor everywhere. I was thinking of using 12mm OSB panels at the bottom, then insulation, and tongue-and-groove boards as the top surface.
