ᐅ Insulation for the base slab / foundation
Created on: 2 May 2011 11:37
minardifan
minardifan
2 May 2011 11:37
I took some thermal images of our house and noticed that the foundation appears quite warm in the pictures. The house is a prefabricated timber frame home built in 1980, with underfloor heating and no basement. Is it normal for the concrete slab to be this warm when using underfloor heating, or can it be effectively insulated afterwards?
Also, apart from the slab and the two very bright windows (which still have the original single glazing), do you see any other areas that could be improved?
Thank you very much for your help in advance!
E.Curb
2 May 2011 12:13
minardifan schrieb:
Is it normal for a floor slab to be that warm when using underfloor heating?
No, you probably have a thermal bridge. The floor slab might not be insulated...
minardifan schrieb:
or can this be properly insulated afterwards?
Difficult without major work.
minardifan schrieb:
Besides the floor slab and the two brightly glowing windows (which still have old window glass), do you notice anything else that could be improved?
Honestly, the pictures are quite small. I can’t really make out much.
Regards
