ᐅ IKEA Metod: How do I install baseboards/skirting boards cleanly and durably?
Created on: 29 Jul 2019 08:37
pioda
Hello everyone, I have a question about IKEA Metod – specifically regarding the installation of the kickboards. I understand that the kickboards are very important for the overall look of the kitchen, especially to ensure they fit neatly and remain secure over time. I’m having trouble fitting the kickboards so that there are no gaps or uneven joints and so that they stay firmly in place. This is particularly challenging when dealing with small unevenness in the floor and corners. I’m wondering what the best approach is. Are there any special installation methods, tools, or techniques that have worked well for you? I want to avoid the kickboards becoming loose or wobbly later on. Thanks in advance for your advice!
FELOTAU
29 Jul 2019 13:27
I find it really frustrating when the baseboards don’t fit perfectly – I initially had similar problems. The tip to use a miter box really helped me. It’s easy to handle and works great for the corners.
It still requires patience, though, because small gaps often appear, especially with older floors. Don’t get discouraged!
One more tip: If the gaps are minimal, you can neatly fill them with a color-matched acrylic sealant – it looks almost invisible in the end and gives a perfect finish.
JAFUHAU
30 Jul 2019 08:12
I can also confirm that fastening with clips makes a difference to prevent the trims from wobbling. Additionally, it helps to slightly adjust the trims at the corners before installation and always insert them with some pressure.
Regarding durability: Avoid direct contact with moisture, as this will cause the trims to swell. This is especially important for floors with underfloor heating.
pikin
30 Jul 2019 09:46
In summary, the following technical points should be noted:
- Before installation, check the floor and level out any unevenness using suitable materials (e.g., leveling compound, shims).
- The use of mitre cuts at corners or precise edge joints is essential for a clean appearance.
- The original IKEA clips ensure reliable fastening to Metod base cabinets.
- To minimize gaps at the wall, a flexible acrylic sealant in a matching color can be applied for adjustment.
- It is important to ensure moisture protection to maintain the long-term integrity of the materials.
These measures significantly contribute to a neat and durable installation of the baseboards.
Tobias
30 Jul 2019 10:22
A quick tip: Denatured alcohol on a cloth works well for wiping away excess acrylic cleanly. Afterwards, nothing sticks, and the trim looks neat.
pioda
31 Jul 2019 08:09
pikin schrieb:
Using miter cuts at the corners or precisely fitting joints is essential for a clean appearance.
Thank you for the summary. It helps me a lot and confirms my impressions from your tips. I will now start sanding and leveling, get a miter box, and place the clips as tightly as possible. Do you have any advice on alternatives to the original clips in case replacements are needed?
