ᐅ I can't find a suitable dust cover for KALLAX compartments.
Created on: 25 Nov 2022 08:17
wenzelge
Hello everyone, I’m facing a somewhat specific issue: I’m looking for suitable dust protection solutions for the open compartments of my IKEA KALLAX shelves. Most covers or doors from third-party suppliers either don’t fit reliably or don’t look good. It’s especially important to me that the dust protection fits well and doesn’t significantly affect the shelf’s appearance. There are simple films or thick plastic sheets that can be cut to size, but these often look makeshift and are inconvenient for frequent access to the contents. Does anyone have experience or know of suitable complete solutions specifically designed for KALLAX compartments? Thanks in advance!
For mounting plexiglass sheets without damage, I recommend using self-adhesive clamping or channel profiles specifically designed for acrylic sheets. These profiles adhere to smooth surfaces and allow for removable fastening. Alternatively, magnetic strips offer a flexible solution, provided the frames are magnetic or can be supplemented with metal backing. Please consider the load capacity and adhesive strength, as frequent removal of dust protection panels can otherwise cause unwanted material wear.
Great discussion here! 🙂 A few weeks ago, I had simple acrylic sheets cut to size and attached them with magnetic strips. It works really well, stays firmly in place, and you can easily remove the sheets when needed. I did it exactly as
RENMA schrieb:mentioned. Definitely recommended!
Magnetic strips are a flexible solution
Roberta schrieb:
Framed sliding doors that can simply be hung in place Thanks for the tip! That sounds really interesting, especially since no drilling is required. Do you happen to know if the sliding doors are also suitable for the KALLAX depth of 39 cm (15 inches)? There are different sizes available, and I want to avoid poor fits afterward.
