ᐅ House extends above ground level – how much soil can be backfilled (with shallow basement)?
Created on: 15 Oct 2022 19:11
Machu Picchu
we are now in the final phase of our house construction.
Because the sewage system on our property is not far below ground level and we did not install a sewage lift system, our basement was only excavated to a shallow depth.
The ceiling height of the basement rooms is 2.50m (8 feet 2 inches), as these areas are intended to be living spaces, unlike the neighboring houses, whose basement heights are lower.
As a result, our front door and the two patio doors are positioned much higher than those of the neighboring houses. In the next few days, soil will be filled up to the level of the terrace and front doors.
I do not want this to turn into a discussion about different construction methods; instead, I am looking for advice on how to best handle this somewhat unusual situation.
First, some photos:
Marked in red are the two patio doors. Soil will be filled up to just below these patio doors, except, of course, at light wells and shafts. The terrace will be paved around the corner, following the two indicated patio doors (because we wanted two sunny sides on the terrace for different times of the day). To the left of the single-leaf patio door (where the exterior plaster ends), a retaining wall will be built from the terrace level down to the ground.
This is a front view. On the left, the construction staircase leads up to the entrance door. The front door is at the same level as the two patio doors.
Here is the view from the back.
This is the view from the back toward the front door.
And here is another rear view including the neighboring houses.
As planned, as mentioned, soil will be filled up to the level of the house and terrace doors, and at this level the garden will be designed on the side of the large double patio door as well as behind the house, with steep slopes created just before the property boundary.
On the front door side, soil will also be filled up to front door level.
Toward the "front" (the side with the single patio door), the street level will be reached by terrace-like steps with 2-3 slope terraces supported by walls/granite.
Our concern now is: if we fill soil all around the house at door level on the side with the double patio door, at the back, and on the front door side, our garden height will be so high that, compared to the neighbors, our house will stand out significantly due to the very elevated ground level.
We are now considering ways to soften this.
One idea is to fill soil to door level only at the terrace wrapping the corner and directly at the front door, and to fill soil, for example, 50cm (20 inches) below door level everywhere else.
This way, the garden level would not be so dramatically higher than the neighbors’.
The problem with this is that we would partially expose the "basement" and areas without exterior plaster would become visible. We would likely need to hire a plasterer on our own to plaster additional areas and paint them with gray base paint. Time is tight because the soil will be delivered for filling within the next days/weeks. How long would such plastering take and what would it approximately cost?
Question to the forum: What do you think about this? Do you have other solutions? Or are our concerns unfounded?
Thank you very much in advance for any advice.
First, some photos:
It got even more absurd – first removing 1 meter (3.3 feet), then adding back 1 meter (3.3 feet) of fill.
Machu Picchu16 Oct 2022 10:4211ant schrieb:
Do you mean like with @Zaba12?
Many here don’t do it that way. I still haven’t fully understood how it came about: after deciding to raise the building, there must have been drawings submitted to the building authority / planning office showing what to expect – or are you building from isolated components without such plans? To clarify again: of course, there are drawings and plans, two of which I copied and uploaded here, but their actual scale or extent wasn’t clear to us in reality.
I also recall that arguments against the lifting system included maintenance requirements, the risk of blockages, and similar issues. But those arguments for and against are over a year old by now. It is what it is at this point...
I skipped reading all the posts, but the pictures are truly “unbelievable.” You can’t seriously be that “stupid” not to include the site in the planning. Which blind fool was responsible for the design here?
Building up the land just creates a hilly landscape that is a) unattractive and b) worse still, won’t be stable in the long term.
Looking ahead is fine, but diagnosis never hurts when it comes to treatment. No, at the moment it distracts from finding a solution.
Machu Picchu schrieb:
I copied and posted two of them here, The drawing of the third gable also looked very familiar to me. Under what name did you discuss it here?
Machu Picchu16 Oct 2022 11:10ypg schrieb:
The drawing of the third gable also looked very familiar to me. Under which name did you discuss this here?Under none... placeholder placeholder
The drawing of the third gable also looked very familiar to me. Under what name did you have this discussed here? I think it is meant here in the thread.
