ᐅ How can I convert IKEA BESTA into a modern lowboard for my living room?
Created on: 7 Feb 2024 14:32
larsenpra
Hello everyone, I am planning to modify the IKEA Besta system into a modern lowboard for my living room. Since I am not satisfied with the standard design, I want to make the lowboard shallower, wider, and more contemporary, ideally combining open compartments with closed elements for a neat appearance. My goal is a lowboard that is both functional for hi-fi and media devices and visually appealing for a modern living space. My questions are:
- Which BESTA components are best suited for such a shallow build?
- How can stability be ensured for wider constructions?
- Are there any recommended tips for DIY customization, such as lighting or surface finishes?
- What tools or materials should I definitely have on hand to avoid missing anything?
I look forward to constructive suggestions and tested solutions to try out!
Wesley
9 Feb 2024 10:46
larsenpra schrieb:
I tend to prefer low-profile plinths, since I want the media console close to the floor.
Great choice! Low-profile plinths not only look very modern but also provide a solid, stable base for the media console.
Regarding attachment: Usually, a sturdy wooden panel, glued and screwed to the bottom of the Besta frame, is sufficient. You can then fix the plinth boards onto that without using the standard feet.
As for cable management and the back panel: I drilled holes in the back panel of my media console (centered and on the sides) to let cables pass through neatly. At the same time, the fixed back panel adds stability. A good combination of open and closed elements works really well and keeps the appearance clean.
Don’t worry—you’ll create a real space-saving solution. Have fun building!
