ᐅ How can I quickly install Ikea Metod cabinets in rental apartments without causing any damage or leaving marks?
Created on: 26 Feb 2021 08:17
Markusfi
Hello everyone, I will soon be moving into a new rental apartment and would like to install Ikea Metod cabinets there. Since it is a rental, it is especially important for me to be able to remove the furniture quickly and, above all, without leaving any damage to the walls or floors.
Does anyone have experience with assembling Ikea Metod cabinets in a way that they are stable enough but can be taken down without major marks when moving out? Are there any special installation methods, fixings, or tips you would recommend?
I appreciate any advice that can help me reduce effort and potential disputes with the landlord.
I once installed a rental kitchen completely without tools, using only special clamp systems and edge protection panels. It worked surprisingly well and left no residue! The key is careful measuring and compensating for uneven floors with adjustable feet. Don’t be afraid to try alternative methods – with a bit of courage, it works great! 😄
For reference: There are so-called self-adhesive mounting plates and hook-and-loop tapes that can provide additional stability under light loads. When combined with sturdy connecting fittings between individual cabinets, this reduces stress on walls or floors. For drill holes, flexible silicone-based sealants or wood filler are recommended, depending on the material of the wall or floor.
FLOMARCOS27 Feb 2021 08:33My advice: Instead, use modular connectors between the Metod elements to create a stable unit. The furniture will then almost stand on its own without needing to be fixed to the wall. Placing rubber mats or felt pads under the feet also protects the floor.
Very exciting discussion here! 😄 A tip from me: If you want to install the cabinets on the wall with as little trace as possible but still need some stability, try these clamp shoes from the furniture store. They gently press the cabinet against the wall at the top without screws and leave almost no marks.
Regarding the floor: Foam pads or closed-cell rubber (such as neoprene) as an underlay can protect the floor and also prevent additional slipping. Good luck with the assembly!
draleo schrieb:
There are so-called self-adhesive mounting plates and hook-and-loop tapes that can provide additional stability under light load.Hook-and-loop tapes seem too unreliable to me for a 2-meter (6.5 feet) high kitchen unit. The static load of kitchen cabinets and possible stresses (e.g., when opening heavy doors) appear problematic.
I would still recommend mechanical fasteners, but installed in a way that allows for easy removal without leaving residues when moving out. Possibly also treating the drill holes to keep them inconspicuous.
