ᐅ Why don’t the drill holes always line up properly during the Malm assembly?
Created on: 16 Dec 2022 08:13
Antadi
Hello everyone, I am currently assembling the Malm shelf from Ikea and have encountered a recurring issue: why don’t the drilled holes always align as described in the instructions? Specifically, I mean that the holes on the side panels and the shelves sometimes don’t line up perfectly, making assembly difficult or even impossible. I have checked several times to make sure I’m not assembling it incorrectly, but it almost seems like the holes on some parts are slightly offset—almost as if there are manufacturing tolerances. Has anyone experienced this or can explain why this might happen? Are there any solutions to work around this issue without damaging the furniture?
nubar
16 Dec 2022 11:25
In addition to manufacturing tolerances and material variations, the installation environment also plays a role. Wood can expand or shrink, especially in more humid or drier rooms. This affects the fit of components.
Assembling the shelf in a space that is well-heated and air-conditioned can make the process easier. Additionally, if in doubt, I recommend pre-checking all drill holes roughly with a center punch or pilot drill bit. This helps to assemble and screw the parts together more precisely.
Antadi
16 Dec 2022 12:02
nubar schrieb:
Besides manufacturing tolerances and material variations, the installation environment also plays a role.
That’s an interesting point I hadn’t considered before. I usually assemble in my apartment, which tends to be quite dry in winter. It might be worth testing whether the same assembly is easier in summer.
Overall, it sounds like some minor adjustments are to be expected, but I hope IKEA will focus more on precision in the future.
NUPIN
16 Dec 2022 13:48
Hey everyone, this might sound a bit annoying, but these kinds of challenges are just part of building on your own! 🙂 I once slightly enlarged my drill holes and screwed in all the screws with a light coating of grease (wax or some oil) – a total game changer!
A small tip from me: Always do a test fit first, then start drilling. This helps prevent wood splitting and keeps everything running smoothly! Good luck and keep at it! 🙂
KNUTGI
16 Dec 2022 14:17
You can almost see the assembly as a little adventure. 😉
Every deviation is an opportunity to refine your craftsmanship!
Also: A difference of just one millimeter (0.04 inches) won’t bother anyone later – except for us enthusiasts during the build, of course 😄
baAlejandr schrieb:
small deviations of 0.5 mm (0.02 inches) are quite common.
I can definitely confirm that. When I tighten the screws, the small inaccuracies are easily compensated.
Elias
16 Dec 2022 16:35
I think it's great that you are gathering so much knowledge here. Sometimes I get really frustrated with these kinds of difficulties during construction. It feels like I’m not able to work properly, even though I’m following everything exactly.
Perhaps manufacturers should focus more on the accuracy of fit or at least clearly state in the instructions that adjustments are normal. That would save a lot of frustration and set realistic expectations.
gojan7
17 Dec 2022 07:42
The instructions often omit this advice. So: stay relaxed and plan for some minor adjustments—this way, everything will work out.
