ᐅ How can I protect BILLY shelves from warping caused by moisture?
Created on: 1 Nov 2022 08:17
nokau
I have a question that’s been on my mind lately: How can I effectively protect my IKEA Billy bookcases from warping due to moisture?
I have several of these shelves in my home office, and I’ve noticed that the humidity level there can sometimes be a bit higher, especially during winter. The back panels and side panels of the shelves are starting to warp or ripple slowly, which obviously doesn’t look great and could also affect stability.
I’m particularly interested in what measures you would recommend to prevent this. Are simple solutions like dehumidifiers or special protective coatings enough? Or are there proven tricks to protect the material without compromising the design or functionality?
What experience do you have with indoor environments that have moderate to slightly high humidity levels?
Looking forward to your tips, recommendations, and honest feedback! Thanks in advance.
Mekau
1 Nov 2022 11:17
Use water-repellent sealing and allow the furniture to dry thoroughly before use. Keep a gap between the furniture and the wall, and ensure good room ventilation.
draFrederi
1 Nov 2022 11:48
Naomige schrieb:
I would be interested to know your exact indoor humidity level?
I’d like to add something: humidity is important, but you can also work with air circulation, so avoid placing the shelf completely flush against the wall.
Also, sometimes just applying a thin layer of wax to the shelves helps; it repels moisture and even looks nice 😉
Who wants to have a dehumidifier running all the time, right? Especially if you are mindful of sustainability, small measures like these can be very helpful.
Maybe give it a try?
Ryder35
1 Nov 2022 12:05
Regular ventilation of the room also helps with protection. Billy does not tolerate constant moisture, but fresh air usually removes it quickly.
Regularly removing dust and dirt also helps moisture to dry faster.
nokau
1 Nov 2022 13:01
Ryder35 schrieb:
BILLY does not like constant moisture
Thank you, that’s an important point! In my study, the humidity currently fluctuates between 55-65% (55-65 percent). It’s not extremely damp, but certainly too high for wood-based materials.
baAlejandr schrieb:
Treating the wood before assembly with special impregnating agents or clear varnish
Would it be possible to apply such treatment afterwards? The shelf is already almost fully loaded, and I can only partially disassemble it. Or is it better to take it apart completely?
Also, how often would I need to renew this sealing once it’s applied? Thanks for any further advice!
baAlejandr
1 Nov 2022 13:22
nokau schrieb:
Could I apply such a treatment afterward as well?
Yes, a follow-up treatment is generally possible, especially on accessible surfaces and edges. It is important that the areas are clean and dry. Pay special attention to corners and edges, as these are the places where most moisture penetrates.
However, the effect is better if everything is dismantled and fully sealed. Without dismantling, you need to be careful not to damage any furniture or items.
nokau schrieb:
How often would I need to renew such a sealant?
This depends greatly on the product, but for interior areas, I find an annual inspection and, if necessary, touch-up advisable. Repair minor damage immediately to prevent more extensive issues.
I recommend testing the treatment first on a hidden spot to check for any color differences.
CARLA
1 Nov 2022 14:03
baAlejandr schrieb:
However, the effect is better when everything is dismantled and fully sealed.
I completely agree. A thorough surface sealing is essential. Partial sealing often results in incomplete protection and long-term issues.
Also, a note: The back panel of BILLY is usually made of thin hardboard material, which is especially sensitive to moisture. If it already shows any deformation, replacing it would be advisable, possibly with a more water-resistant back panel.
Regarding humidity: Try to keep it below 60%, ideally between 45-55%. This significantly reduces the risk.
