ᐅ How can I protect BILLY shelves from warping caused by moisture?
Created on: 1 Nov 2022 08:17
nokau
I have a question that’s been on my mind lately: How can I effectively protect my IKEA Billy bookcases from warping due to moisture?
I have several of these shelves in my home office, and I’ve noticed that the humidity level there can sometimes be a bit higher, especially during winter. The back panels and side panels of the shelves are starting to warp or ripple slowly, which obviously doesn’t look great and could also affect stability.
I’m particularly interested in what measures you would recommend to prevent this. Are simple solutions like dehumidifiers or special protective coatings enough? Or are there proven tricks to protect the material without compromising the design or functionality?
What experience do you have with indoor environments that have moderate to slightly high humidity levels?
Looking forward to your tips, recommendations, and honest feedback! Thanks in advance.
Naomige
2 Nov 2022 08:17
Good morning nokau,
As you can see, there are several ways to approach this issue. If you decide to use after-treatment, also check how your items are stored on the shelves. Moisture-sensitive objects should not be placed directly on the shelves or against the walls.
Sometimes placing a thin separating film can help prevent the wood from being directly exposed to moisture.
In my experience, maintaining room temperature around 20°C (68°F) along with regular ventilation prevents many moisture-related problems.
Good luck with your implementation!
draFrederi
2 Nov 2022 10:03
One small tip from me: If you want to get a bit creative, you can cover the visible surfaces with self-adhesive wood-effect film. This also provides additional protection against moisture and is inexpensive. 🙂
Of course, this does not replace proper sealing, but it can help, especially in areas that are heavily used.
