ᐅ Garage in a timber frame construction, possibly as a kit building system
Created on: 22 Aug 2016 13:16
SKFBG
we are currently planning to build a garage. After some research, I would like to construct a garage using timber frame construction myself. The exterior walls should then be plastered to match the appearance of the house. So far, I have only found one supplier from southern Germany offering such a kit.
My questions are:
- Does anyone know manufacturers of garage kits using timber frame construction (no concrete and not a log wood garage)?
- Or is it the structural engineer’s responsibility to determine the dimensions and arrangement of the timber?
I have been looking for answers for a long time. Maybe someone here has experience with a similar project.
Thanks and best regards
SKFBG
29 Aug 2016 08:58
@sven0924 I can’t estimate the costs based on your dimensions, but the providers are very fast and straightforward when preparing quotes. Often, you can submit a request with your specifications through their contact page on the website, and the quote usually arrives within 1 to 2 days.
borderpuschl
29 Aug 2016 11:11
Regarding the carpenter: A structural engineer must calculate the structural design. However, carpentry companies always work together with a structural engineer, and due to their extensive experience, their plans usually fit correctly the first time. Therefore, in most cases, the quote should be accurate. (There are always exceptions.)
SKFBG
29 Aug 2016 12:05
Ah, okay. Thanks for the tip.
