ᐅ Garage Location on the Property – A Decision-Making Guide
Created on: 25 Nov 2022 09:23
Teilzeitplaner
We are considering a building plot that is currently being reclassified from former farmland to residential land in the development plan, together with the municipality / local building authority. During this process, the road layout was changed, and now I am uncertain about the best way to position the garage on the property. Since the west / south side is practically unbuildable, I would like to have a fixed covered terrace on the west side, which could potentially include a lounge area, barbecue spot, or an open conservatory.
This is not primarily about the floor plan; however, the schematic drawings attached represent the situation quite well. I would be very grateful for your thoughts. 🙂
If any information is missing, I will be happy to provide it.
Thank you very much in advance! 🙂
Grundriss eines Einfamilienhauses mit Garten und Carport, farbige Innenaufteilung.
Kleiner Hausgrundriss in der Mitte eines Baugrundstücks mit Parkplätzen vor dem Eingang.
Grundriss eines Einfamilienhauses mit Parkplätzen links auf unbebautem Grundstück.
Grundriss eines Wohnhauses im Grundstück mit zwei Autostellplätzen daneben.
X
xMisterDx
11 Dec 2022 11:44
Usually there is always something off, like a polygonal curve or similar. If there is even a surface-mounted installation, almost all heights will change significantly.
Seriously?
Here in the development area, at least 60 out of 88 plots are perfectly rectangular.
