we are currently considering how to design the front garden fence. It is decided that it should be 1.20m (4 feet) high and made of anthracite-colored iron or aluminum. Our house has a modern white-gray color scheme. Now the question is how to construct the posts — either metal as well or perhaps masonry, but how exactly? What would be best: plastered, made from ready-made bricks, or covered with brick slips? What could be repaired later if someone accidentally hits it (provided the post is still standing)? What have you done or what would you do?
Sabine
Sabine
Silent01018 Oct 2019 09:39Hello Sabine,
I won’t be answering your questions directly, but I have looked into this type of fence solution myself, so here are a few insights from my side:
I am a big fan of iron fences between masonry posts. I don’t know if your budget is limited, but this is the most expensive fence option I know.
From the local metalworker’s point of view, it’s unaffordable. Even online suppliers who weld in India and coat in Germany (Google "ELEO") charge around 150 to 200 euros per linear meter for a height of 120cm (47 inches). This price doesn’t include the posts yet.
Visually, the fence has to match the house, because such a fence makes a strong impression. However, if there is just a small prefabricated house behind it, it won’t look right.
I advise against plastering masonry posts, as I haven’t seen any fence older than 10 years without some plaster chipping off. I also like the solution of metal posts coated in the same finish as the fence.
Good luck
Good luck
Hello Sabine
There are nice prefabricated designs available.
If the posts are going to be built from masonry, they need to be placed on a foundation. Ideally, 80cm (31.5 inches) deep. On top of that, use formwork blocks. These come in various styles. They are filled with concrete, topped off with a cap, and that’s it. If a car hits it, the car will be damaged. Place a metal fence in between and everything is good to go.
Steven
Steven
Steven schrieb:
There are some good prefabricated designs available.
If the posts are going to be built from masonry, they need a foundation. Ideally, 80 cm deep (31.5 inches). Then concrete blocks on top. Do you mean blocks that are already finished, or will the blocks still be covered with a facing brick or plastered? I’m a bit concerned that if someone accidentally bumps or scratches it, you might have to replace the entire masonry post, and the blocks may no longer be available. That’s why I think a plastered post might be "simpler" to repair.
Sabine
Hello Sabine
The blocks are ready to use. They are simply stacked on top of each other and filled with concrete. They are hollow inside, which is why they are called "formwork blocks." I built my fence (about 30 meters (100 feet)) with these blocks (manufacturer Kann) and I am very satisfied.
Steven
Steven
