ᐅ Front door with or without a sidelight
Created on: 29 Nov 2021 07:26
Mateo84
My windows and front door have now been measured (city villa), and the installer asked whether we are sure we want a sidelight next to the front door. He personally would widen the door slightly and omit the sidelight.
Here is the door as currently planned:
2D floor plan of a house with dimensions and labels
What do you think? Is the sidelight too small and would it look odd? Would a wider door be more comfortable and "nicer" here?
Mateo84
Alessandro
29 Nov 2021 09:44
Oh, so apart from the door, nothing else can be changed, I see. In that case, I would choose a wider door with the largest possible glass panel.
face2629 Nov 2021 09:45
Alessandro schrieb:
I would also keep the side strip. Why do you want to skip the canopy?
Did I miss something? Was that mentioned somewhere?
The shell of the building is already in place. Don’t complicate it with things that can’t be changed later.
Otherwise, the hallway will definitely be very dark. You have enclosed rooms everywhere. I would consider installing a door with the largest possible window.
Mateo84
29 Nov 2021 09:51
@face26 That is exactly my plan now. What door width should one choose? The brick opening measures 1.40 m (4 ft 7 in). Door 1.10 m (3 ft 7 in) and frame 15 cm (6 inches) each, or what is common there?
Harakiri
29 Nov 2021 10:00
We faced almost the same dilemma; in our case, the space was even tighter (1310 mm (51.6 inches) rough opening). We decided to leave out the side panel, as it would have looked quite awkward, and instead integrated the glazing into the door (actually, we have two doors now): door width 1240 mm (48.8 inches), with frame extensions of 30 mm (1.2 inches) on each side.
evelinoz
29 Nov 2021 10:21
The bathroom door should open outward. Emergency responders cannot enter if someone has collapsed inside.
The kitchen door would be better opening outward to prevent someone carrying a tray full of champagne glasses from having an accident.
The 1-meter (3.3 feet) wide living room door is tiny for the room size and feels unbalanced. You always have to go around the wall first if you want to go upstairs or come down from upstairs, which is odd.
Tolentino29 Nov 2021 10:25
To answer your question: Make the frame as narrow as possible, the door as wide as possible, and the glass element as large as possible. I wouldn’t worry about details like the frame being exactly the same width as the brick or anything like that.
