ᐅ Open-plan kitchen layout in a prefab house
Created on: 30 Nov 2022 10:30
Antonino85
Antonino85
30 Nov 2022 10:30
I hope you can give me some advice on my project.
The building is a prefabricated house from Weberhaus, built in 1985.
In the attached drawing, the walls marked in red were already there. After consulting with Weberhaus, these are the supporting beams.
Now, we want to create an open kitchen area (on the left). We would like to remove the walls there while keeping the beams in place.
The contact person at Weberhaus said this is not a problem as long as we leave the central wall between the living area and the hallway, as well as the staircase, untouched. According to him, these drywall partitions provide stiffness and prevent the house from eventually becoming misaligned.
Additionally, we would like to move the water pipe about 1m (3.3 feet) to the right in the kitchen area. Is this easily possible in a prefabricated house?
Tony
Grundriss eines Erdgeschosses mit Wohn-, Koch-, Essbereich, Schlafzimmer und Bad.
hanghaus2023
30 Nov 2022 13:05
That’s definitely possible. However, I would ask Weberhaus to provide that in writing.
Try marking the change on the plan. Where exactly are the studs that you want to keep?
My brother did something similar in an older house. However, that was a timber-framed building. In that case, it was done without the infill panels and included a passageway.
Antonino85
1 Dec 2022 14:55
hanghaus2023 schrieb:
That should be possible. However, I would get written confirmation from Weberhaus.
Try marking the changes on the plan. Where exactly are the posts that you want to leave in place?
My brother did something similar in an older building. However, that was a timber-framed house. In that case, it was without the infill panels and included an opening.
Thanks for your feedback.
The posts or beams would remain in the area marked by the green line.
