ᐅ Exterior wall air vents
Created on: 14 Sep 2010 01:48
Faktus2010
Faktus2010
14 Sep 2010 01:48
Hello, a construction company is offering us a ventilation system with built-in exterior wall air vents installed flush in the exhaust rooms. Is this legally required (according to the state building regulations), and is it useful? The idea is that fresh air should flow in due to the resulting negative pressure... but what about the heat loss of the house if I have air vents everywhere?!
€uro
14 Sep 2010 08:28
Faktus2010 schrieb:
...Is this legally required (according to the state building code) and is it reasonable?!
According to the state building code, ventilation systems are only mandatory in interior rooms without windows (bathrooms, toilets).
Faktus2010 schrieb:
...Due to the resulting negative pressure, fresh air is supposed to flow in... but what about the heating loss of the house if I have air vents everywhere?!
If you have air vents everywhere, a central ventilation system with heat recovery would be more advisable.
It is important that the planned air volumes are included in the heating load calculation. Otherwise, there can be unpleasant surprises.
Best regards.
Faktus2010
14 Sep 2010 12:17
Who can advise me?
Well, maybe not everywhere. The air vents are planned in the exhaust rooms: kitchen, guest toilet, bathroom, and utility room. The indoor air is supposed to be continuously renewed this way. Who performs a heating load calculation? And who can I contact to check if the planned air-to-water heat pump is the right one?!?
€uro
14 Sep 2010 14:28
Faktus2010 schrieb:
..Well, maybe not everywhere. The air vents are planned in the exhaust rooms: kitchen, guest toilet, bathroom, utility room.
So, it is indeed a standard mechanical ventilation system with heat recovery. Usually, the supply air is also delivered to the individual (supply) rooms through ducts from the ventilation unit. Having a building "peppered" with numerous supply air openings is somewhat unusual.
Faktus2010 schrieb:
..Who performs a heating load calculation? And whom can I contact to check if the planned air-to-water heat pump is the right choice?!?
I do, for example. Please send me an email or private message for that.
Best regards.
Shoko
23 Sep 2010 14:51
This is not unusual, but completely normal for a decentralized mechanical ventilation system with heat recovery.
€uro
23 Sep 2010 15:58
Shoko schrieb:
This is not unusual, but completely normal for a decentralized controlled residential ventilation system.
Correct, that is exactly where the problem lies!
Best regards.
