I would like to increase the number of electrical outlets in some areas of my (possibly new) house and also install wireless switches for the roller shutter housings flush-mounted.
Now my question:
When I install a new electrical box, I drill an 80mm (3 inch) hole and plaster the boxes in. If I want to place another box next to an existing one, I would drill an 80mm (3 inch) hole into the old box.
If I drill a 68mm (2.7 inch) hole instead, I’m worried that the box won’t fit securely because there won’t be enough space.
How do you solve this problem?
Thanks.
Now my question:
Thanks.
Caspar20203 Nov 2018 19:23Who makes such large holes in the walls? Whether new construction or modifications, they are always 68mm (2.7 inches).
Otherwise, it’s a waste of plaster. Plus, it’s fiddly work to get them aligned properly.
Caspar2020 schrieb:
Who makes such large holes in the walls? Whether new or retrofitting, always 68mm (2.7 inches).
Otherwise, it’s just a waste of plaster. Plus, it’s a hassle to align everything. The outer diameter of the sleeve is about 65/66mm (2.6/2.6 inches), right?
Is that enough plaster on the outside by the millimeter?
Should you drill a little deeper instead?
Caspar20203 Nov 2018 20:23It just needs to be solid. Whether there are 2, 5, or more layers of drywall around it doesn’t matter.
I’ll add a bit more at the back.
The best option would be to chisel out the existing box and then fit both together before installing them as one unit. Using only a small amount of plaster or other suitable materials for this risks drafts through the boxes, especially if they are located in exterior walls.
