ᐅ How to Equip a Shelving Unit with Rolling Rails?
Created on: 22 Feb 2015 09:13
Arongau
Arongau
22 Feb 2015 09:13
I am currently considering equipping my Billy shelving unit with roller tracks to improve flexibility and ease of use. My question is: which types of roller tracks are best suited for heavy-duty use on a Billy shelf, and what is the best method for technically installing them?
It is important to me that the shelf can be pulled out smoothly and easily without compromising stability. Are there specific models you would recommend? Also, regarding the mounting – are simple screws sufficient, or is it better to use more complex mounting kits?
I look forward to your experiences and tips. Thanks in advance!
teo33
22 Feb 2015 09:48
For Billy shelves, ball-bearing roller runners with a width of about 350 mm (14 inches) are best suited. These can usually be attached to the side panels with simple screws. It is important that they are rated for the weight.
deoke
22 Feb 2015 10:35
Hello Arongau,
I’ll approach this topic in more detail because there are some important points to consider when installing roller rails on a Billy-style shelving unit. First: How heavy will the shelf be loaded? This affects the choice of rails. For medium loads, I recommend ball-bearing full-extension slides with a load capacity of at least 30 kg (66 lbs) per pair.
Regarding installation, you should also make sure that the rails are attached not only to the side panel of the shelf but also to the drawer or pull-out simultaneously. Usually, you drill pilot holes exactly and use appropriately long wood screws, ideally with pilot drill holes to avoid damaging the material.
Another tip: The side panel of Billy-type shelves is often relatively thin (about 16 mm (0.6 inches)), so you should use slim rail systems that don’t require removing too much material. Sometimes it also makes sense to attach a wooden strip inside the side panel to provide a more stable mounting.
The key concepts here are “load distribution” and “precision of alignment.” A roller slide installed at an angle can start to stick or jam after a short time.
One more question about the load: Do you plan to store only books or heavier items as well? In that case, a slide with metal profiles and ball bearings might be a better option, as they can handle the load more effectively.
lenren
22 Feb 2015 11:02
There are roller rails available in various lengths. A length of 350 mm (14 inches) is standard for Billy. Simply attach them with wood screws. Sturdy enough for books.
NAU34
22 Feb 2015 12:26
Hey, imagine how cool it would be to turn your little Billy shelf into a sled! 🙂
Joking aside, when using roller rails, go for ball-bearing rails—they’re smooth and sturdy. When installing them, try pre-drilling—it prevents problems and ensures strong connections. And remember: sometimes a little clearance is worth its weight in gold, so nothing gets stuck—a small amount of tolerance makes operation much smoother.
Good luck, I’m sure your shelf will become a real speedster! 😉
glamo8
23 Feb 2015 08:59
deoke schrieb:
First: How much weight will the shelf be loaded with?
That’s also my question. The load determines the choice of slides. For light to medium loads, just use standard drawer slides. For heavy loads, it’s better to choose heavy-duty models.
