ᐅ Does your Kallax shelf work well as a room divider with pets that like to jump?
Created on: 22 Sep 2022 10:12
Puke44
I’m planning to use an IKEA Kallax shelving unit as a room divider in my apartment. However, I have two quite agile cats who like to jump and climb. So, my question is: does your Kallax unit hold up well as a room divider with pets that frequently jump on and climb it? Are there any experiences regarding its stability, tipping risk, and possible damage to the shelving unit? I want to avoid the unit constantly tipping over or being unsafe, so I would really appreciate your assessments and tips.
Wesley
23 Sep 2022 11:05
I use my Kallax as a room divider, and my cat is an expert jumper ;-). My tip: you can also stick the shelf to the floor molding at the bottom with double-sided tape, which greatly increases stability. Additionally, I fixed a small scratching mat on the top surface, so the texture for climbing and jumping stays intact, but the surface is protected. The whole setup has been rock solid for months. And the shelf still looks stylish – what more could you want? 🙂
bapar
24 Sep 2022 09:47
For long-term stability of the Kallax when used as a room divider with pets that jump, I recommend the following approach:
1. Anchoring: Use the original IKEA wall brackets, supplemented by sturdy angle braces at the bottom and top corners. It is important that the shelf is secured both at the height and at the base to prevent tipping forward or sideways.
2. Weight distribution: Place heavy items in the lower compartments to keep the center of gravity low. Depending on the use, this prevents the shelf from tipping over easily, even with intense jumping.
3. Surface protection: If cats frequently use sharp claws, I recommend a protective layer, such as plexiglass or reinforced film, which can be applied on the top and sides. This increases durability.
4. Floor: If possible, use a dust-free, non-slip mat. A rug can make the shelf unstable due to weak fixation.
5. Follow-up question: Do you use the shelf mostly for heavily loaded storage or more lightly? And what is the size of the floor area the shelf covers? These details are important to assess the stability more accurately.
