ᐅ Disposing of Large Amounts of Garden Waste
Created on: 20 Feb 2023 16:42
Adam26a
Adam26a
20 Feb 2023 16:42
Over the weekend, I cleared about 35m x 2m x 5m (115ft x 6.5ft x 16ft) of hornbeam hedge on my undeveloped plot. By calculation, that amounts to around 350m³ (12,370 cubic feet). It’s probably less if you compress the branches a bit.
I need this space for construction. The hedge will be replanted afterwards, but clearing it was essential for the build.
My question is, what should I do with the material? I could try shredding it with a garden shredder, but that will likely take a long time.
Do you have any ideas? The fire department no longer accepts donations for Easter bonfires. The recycling center also declines due to the volume.
Unfortunately, I can’t just place a container and fill it for collection because my property doesn’t yet allow for that option.
Thanks for your suggestions.
SumsumBiene20 Feb 2023 19:33
You can rent a large wood chipper. It costs 165€ per day here. Found the ad on e-ka.
Tolentino20 Feb 2023 19:40
The wood chips, if they survive the construction phase undamaged, are worth their weight in gold.
Adam26a
20 Feb 2023 20:18
Thanks for the tip about e kl. I actually found something that could work for me. I will call them tomorrow.
I forgot to mention that I live in Hamburg.
Adam26a
20 Feb 2023 20:19
Tolentino schrieb:
The wood chips, if they survive the construction phase intact, are actually worth their weight in gold.
What is it used for then? As fertilizer?
Tolentino20 Feb 2023 20:32
That is true, especially if you have it piled up long enough. But you can also use it to cover the soil around your plants during their early growth phase; this helps protect against heat and cold and retains moisture in the summer.
Additionally, it always smells fresh, which I find pleasant.
