ᐅ Conversion from a double sink faucet setup to a single faucet unit
Created on: 12 Feb 2023 23:09
Sebastian1234S
Sebastian123412 Feb 2023 23:09Hello everyone,
we currently have a double washbasin in the bathroom with two separate hot and cold water connections.
We now want to switch to a single washbasin with one faucet.
To avoid a dead-end pipe, the redundant pipe should be completely removed. However, this would require opening the wall.
Are there other options, for example, connecting both hot water lines and then feeding one line to the faucet? The same with the cold water lines.
Sebastian1234 schrieb:
We currently have a double sink in the bathroom with two separate hot and cold water connections.
We now want to switch to a single sink with one faucet.
To avoid a dead leg pipe, the redundant line should be completely removed. However, this would require opening the wall. Are you sure that the connections don’t first branch off underneath the sink?
Sebastian123413 Feb 2023 08:08I have two separate angle valves for hot water and two for cold water.
I’m currently on my way to work. I can attach a photo this evening.
O
OBM München19 Feb 2023 13:41If you only close a hot water valve and a cold water valve ... this could lead to a Legionella problem.
A 10 cm (5 inches) long dead-end pipe is not recommended.
