ᐅ Cornices on the wall cabinet
Created on: 3 Jun 2013 08:27
Sektionschef
Hello again,
During the kitchen planning, another question came up regarding the upper cornice moldings:
If I select a Lidingö wall cabinet with glass doors for my kitchen and choose a cornice molding in the planner options, the online planner creates the following:
It places a profiled decorative molding (Item No. 800.906.38) on the front and a “standard” molding on the sides, as shown in the picture. This side molding does not appear in the planner’s item list.
For this wall cabinet, I also selected the end panels. The planner draws the end panels so that they extend slightly below the cabinet (presumably for a lower decorative molding), but at the top, the panel aligns exactly with the cabinet height. This creates a “step” between the end panel and the side decorative molding at the top.
My question to you:
Which upper side molding does the online planner add? What is the item number for it?
How should the upper cornice moldings generally be installed? Should it be done as the online planner suggests, or is it better to use the profiled decorative moldings on the sides as well?
Sektionschef
Sektionschef
5 Jun 2013 10:08
Consider waste and miter cuts; when installing, additionally bond the miter cuts with silicone and secure them with clamps until the silicone cures. This results in a cleaner and neater appearance.
Good tip!!!
Does I-Sell actually account for waste, since the online planner doesn’t?
I figure if I want to order the kitchen correctly the first time, I need to double-check and recalculate all these things, right?
Sektionschef
Z
zetterberg
5 Jun 2013 15:10
I can't say for sure, but based on what was written above, probably not.
At the very least, every good salesperson should account for material waste.
Nayla_1068
5 Jun 2013 22:46
Does the I-Sell system take material waste into account, since the online planner doesn’t?
Section Chief
... I-Sell doesn’t, but the kitchen salesperson you trust does...
We still need to have a role, after all. If the planner did everything perfectly, we’d be unnecessary, wouldn’t we?
Nayla_1068
