ᐅ Creating a Ubiquiti UniFi Access Point Heatmap as a Demo
Created on: 30 Jun 2020 13:43
imsi123
Hello, no idea why my last thread was deleted... I wanted to position the access points myself in my floor plan to see how the Wi-Fi range changes. Someone had already done something like this for me in the deleted thread (which is now gone). However, I can’t add any access points at all because I don’t have a system running?!?? Is there a way to do this in a demo mode or something? I haven’t found any information about this.
Teemoe86
2 Jul 2020 13:54
Daniel-Sp schrieb:
Quick question,
which file formats can the software import?
Regards, Daniel
Google Maps, .gif, .jpg, .png.
You then measure the longest possible distance on your plan using a line.
After that, you can trace all the walls.
Unfortunately, there is only a limited selection of walls available.
imsi123
3 Jul 2020 11:20
No idea, the field is grayed out for me. So I can’t insert anything... damn... tough luck. Maybe you need to have at least a real device running.
Grobmutant
3 Jul 2020 11:44
A few weeks ago, I successfully used it and I don’t have a single Ubiquiti device yet. So, it should actually work that way.
Which software version are you using?
Teemoe86
3 Jul 2020 12:54
Six months ago, there was an issue where virtual devices could be seen but could not be pinned on the map. This has been fixed.
There is also a problem with some older versions, for example 5.6.x.
The current version is 5.13.x, and it works with that.
imsi123
3 Jul 2020 13:24
Strange, I got version 5.6.42 installed, even though I downloaded the new version 5.13.xx from the website. Now I’m downloading 5.12.xx again.
Teemoe86
3 Jul 2020 13:43
If you are using Windows as your operating system, you might still have the older version installed as a "Windows Service" – it’s worth checking the shortcut you use to start the controller. Look into the properties and check the file path.
By default, the user folder is always used for installation, even if the old installation is located elsewhere. Therefore, your shortcut might simply be launching the old version instead of the new one.
