ᐅ Cost Difference for Roofing a Double Garage
Created on: 16 Apr 2017 10:13
Aliban2014
Aliban2014
16 Apr 2017 10:13
We are still in the early planning stages for our house, as we are waiting for approval for the building plot, but I have the following question in mind for which I haven’t yet found reliable information here in the forum or online:
Does anyone have experience or information about whether, and if so approximately how much, the cost difference is between building a masonry double garage with a pitched roof, for example, versus covering it with a terrace (including a roof extension with 1.0m (3.3 ft) height according to the development plan)?
The theoretical practical value of a terrace on the garage is obviously much higher, regardless of how often it would be used.
I’m just wondering if there are significant cost differences here?
I’m leaning more towards a standard roof, but if the terrace option is significantly more expensive, I would rather go with the terrace on the garage.
O
Otus11
16 Apr 2017 21:04
Preliminary question: Garage built on the boundary line?
If yes, obtaining approval for the garage including the terrace on top will be difficult....
Aliban2014
17 Apr 2017 11:10
Yes, the garage would then be on the property boundary.
I assume it would be approved because the development plan clearly states that a roof terrace can be built on the garage, provided that the roof terrace has a parapet or roof edge at least 1.0 meter (3.3 feet) high.
Whether this applies only to garages located within the "normal" building zone (i.e., the one for the main single-family house) and not to garages in the "small" building zone (5 x 2 meters (16.4 x 6.6 feet)) is not clearly specified in the development plan.
I would clarify the approval-related question in advance if this issue becomes concrete.
For now, I just wanted to research which solution would be (significantly) more expensive.
jaro22
26 May 2017 16:55
Hi. We are planning something similar. The gable roof costs us exactly twice as much as the flat roof option.
Due to this requirement from the development plan / zoning plan, we decided on a green roof.
The cost for a double garage made of steel, including an electric door and a 3 x 2 meter (10 x 6.5 feet) shed attached, is 11,500. The gable roof is 20,000.
tomtom7927 May 2017 10:44
Waterproofing of the flat roof garage included for 11,500? That sounds a bit too cheap to me.
