ᐅ Construction Professionals <-> Sales Representatives
Created on: 25 Oct 2015 21:39
nistibee
nistibee
25 Oct 2015 21:39
I have already read several times that you should make sure to conduct negotiations with the building company through construction professionals and definitely not with salespeople. A silly question: how can I tell the difference? Should I ask the person to show some kind of documentation proving that they are really a construction expert? Does something like that exist?
Legurit
25 Oct 2015 22:11
In many cases, you won’t have a choice – many companies we visited handled these separately.
That said, not all salespeople are automatically unprofessional – we encountered both types: those who could answer questions and those who couldn’t, or even worse, those who made things up.
What is probably true is that you shouldn’t rely on “promises” and “assumptions” – like the idea that “yes, 10cm (4 inches) taller windows are no problem and can easily be changed when the time comes,” only to find out in the end that it’s not possible because it would compromise the stability of the house.
Are you concerned about things like this, or are you looking for neutral advice? You’re most likely to get that from an architect or an expert (although they, of course, also have strong opinions). A specialist from a company that only builds with aerated concrete blocks is unlikely to start praising hollow bricks or promoting prefab houses from Denmark.
Bauexperte
26 Oct 2015 00:23
Good evening,
nistibee schrieb:
I have read several times that negotiations with the construction company should be conducted with construction professionals and definitely not with sales representatives.
What, in your opinion, is the difference between sales representatives and construction professionals?
Salesperson "A" sells you offer "A"... sales representative "B" sells the product of their business partner "B," and even the architect sells you their product "C." In other words, everyone is a salesperson 😉
Best regards, Bauexperte
SirSydom
26 Oct 2015 16:16
The real question is whether the seller is "just" a seller or, as in my case, also the project manager (or architect, or something else).
It was personally important to me to have the same contact person from start to finish.
Musketier26 Oct 2015 16:26
SirSydom schrieb:
The real question is whether the seller is "just" a seller, or—as in my case—also the construction manager (or architect, or something else).
For me, it was important to have the same contact person from start to finish.
This will only happen in very rare cases or with very small companies, and if they were good at both roles, then you probably found a very rare example.
SirSydom
26 Oct 2015 16:47
Small construction company.
The question is – what makes a good salesperson, who do they serve better (the company or the client?), and do you actually want a good salesperson? 😉
