ᐅ Complete duplex with a separate granny flat/apartment. What are the base and eaves heights?
Created on: 24 Mar 2017 11:30
michi216
We are planning to build a complete semi-detached house with a granny flat.
Now, one provider is telling me that this is not possible because of the plinth height (0.5m (20 inches))?
Could that be true?
The eaves height would be 6.5m (21 feet) or 12m (39 feet) available.
Thanks for your help and ideas.
Could that be true?
Yes, okay... 4.5m (15 feet) ceiling height is quite something :-) Does anyone actually build like that? It’s usually more for three stories.
A full storey counts as 1.4m (4.6 feet), right?
And why wouldn’t you combine WA3 with WA2? That’s how it was done with WA1 as well?
We’ll probably have to ask the local authority for a 1m (3.3 feet) plinth height, please :-)
And sorry for all the questions ;-)
If you withdraw 100 euros from an ATM without specifying the denominations, you usually receive one 50, one 20, two 10s, and two 5s—the typical “housewife mix.” Municipalities apply a similar approach when designating residential areas: these areas are divided into zones intended for specific types of houses. Lot sizes suitable for townhouses are generally too small for detached single-family homes. In land redistribution procedures, the aim is to reclaim the lot sizes originally contributed based on the new zoning layout. Size categories are often assigned by blocks. Where the municipality itself was the owner and divided the land recently, the process is similar—based on expected demand, as described above.
That may well be the case and would be an explanation. However, the main focus was probably on a uniform maximum ridge height. Whether every builder can fully utilize this is less important.
Die Traufhöhe zielt eventuell auf drittes Geschoss mit Dachterrasse ab?
