ᐅ Central room temperature controller for the fan coil unit (FCU) of the underfloor heating system
Created on: 23 Jun 2020 11:34
micric3
Is there a way to control the ERR centrally on one device, so that, for example, the children cannot adjust the underfloor heating control (heating circuit)? Also, I don’t mind not having a thermostat with a controller in every room. What would be the alternative? Are there sensor-only devices that, for example, send the temperature wirelessly to the central unit, or does a separate fixed setting for the respective heating circuit also count as an ERR?
Good luck
Good luck
Alessandro9 Jul 2020 11:43Who is responsible for the hydraulic balancing if I consider the installer incompetent (at least in these matters)? When is the best time to carry it out? After the first heating season?
It seems that making precise adjustments is not really worthwhile for a professional, as the effects of changes only become visible after 2-3 days. This means a professional would have to come by several times in a row for 5 minutes each.
So it’s best to read up thoroughly and do it yourself.
Daniel-Sp9 Jul 2020 11:48Alessandro schrieb:
So you mean that I should set all thermostats permanently to the maximum temperature and adjust the target temperature for each room directly on the heat pump?Exactly. If this is done, any existing bypass valve should also be closed so that the entire flow goes through the underfloor heating and not a large part bypasses it directly into the return line.D
Daniel-Sp9 Jul 2020 11:49Alessandro schrieb:
Who will carry out the hydraulic balancing if I consider the installer incompetent (at least for these tasks)? When should it be done? After the first heating season?You will have to do it yourself during the heating season.Alessandro schrieb:
So you mean I should turn all thermostats permanently to the maximum temperature and set the target temperature for each room directly on the heat pump? Not exactly. You can’t set the desired temperature for individual rooms directly on the heat pump. (There are systems with such control, but that would be another technical topic.)
You adjust the temperatures of the individual rooms through balancing. Use the "worst" room as a reference point. Turn all radiator valves fully open. Then adjust the flow temperature so that your target temperature is reached in the worst room. The others will likely be too warm at first. Then you gradually close their valves until the correct temperature is reached there as well.
This process obviously can’t be done in 5 minutes.
It’s a simplified explanation, but if you search online, you will find guides on this.
